dentree
Joined: 01 May 2009 Posts: 247 Location: Melbourne Australia
TV/Projector: BARCO GRAPHICS 808 BARCO GRAPHICS 801
| Posted: Sun May 03, 2009 5:35 am Post subject: BARCO RED GUN |
Have just aquired a BARCO DATA 808s (as a backup) for my BARCO GRAPHICS 808, the question I have is: When his machine when turned on the RED gun takes some considerable time to warm up to the point where is is of normal brightness giving the correct color balance to the image, it does however kick into life and all is well from that point on, essentially the green and blue are full on where the red lags behind for about 15 minutes.
Is this the gun on it's way out, or is there somewhere else I should be investigating?Thanks
r.bauer
Joined: 08 Apr 2006 Posts: 280 Location: The Netherlands
| Posted: Sun May 03, 2009 7:14 am Post subject: |
Try to swap a neck board and see if the problem moves with the neckboard, or else swap the input cable between red and green if they are long enough.
dentree
| Posted: Mon May 04, 2009 11:34 am Post subject: BARCO RED GUN |
Thank you for your reply, I will give your suggestion a try as soon as I have a bit of time to play, will let you know the result, many thanks
Regards,
Trevor
