drobflett
| Posted: Tue Apr 21, 2009 11:06 pm Post subject: Is a switch connected to sony 1272 good for a HDfury 1 or 2 |
im a neewbie so i hope im posting my question in the right forum. I bought a sony 1272 with the switch in my stereo rack, my question is it better to connect an hdfury 1 or 2 to the switch with reguards to the the length of the long cable
jkruger
| Posted: Wed Apr 22, 2009 4:03 am Post subject: |
The HDFury2 is a better device and can drive longer cable runs than the original. It has more capabilities and in the long run is a better value.
| Posted: Wed Apr 22, 2009 3:53 pm Post subject: Re: Is a switch connected to sony 1272 good for a HDfury 1 o |
| drobflett wrote: | | im a neewbie so i hope im posting my question in the right forum. I bought a sony 1272 with the switch in my stereo rack, my question is it better to connect an hdfury 1 or 2 to the switch with reguards to the the length of the long cable |
What "switch" do you have? Is it a PC 1271? If so what input card(s) does it have?
If the card(s) are IFB-10 or IFB-11 then you'll need the HDFury2 for the driver circuit
If the cards are IFB-12(s) then you can use an HDFury1. The IFB-12 has a buffer ( driver ) in the card.
Your other option is to get an HDFury1 and a GammaX or Buf2000 and run those into the IFB-10 or IFB-11 card.
Alternatively you can try running the HDFury1 into the IFB-10 or IFB-11 and put the GammaX or Buff2000 AFTER the switcher ( on the output side ) to see if that will give you an OK picture.
I have a PC1271 and have tested most combinations except the GammaX/Buf2000 on the output side.
EDIT: Spellignign
