Nec issue
quest_enterprises
Posted: Sat Apr 18, 2009 5:58 am    Post subject: Nec issue
I am attempting to converge a recently received NEC 750 and it states the color is not applicable for the blue tube. Whats the issue. It worked when i first received it.
bbfarmht
Posted: Sat Apr 18, 2009 6:01 am    Post subject:
You don't have the blue selected. You have to hold ctl then press the blue.
You must make sure when working on separate colors that you select the color also!
Adam
Benjamin Franklin
bbfarmht
Posted: Sat Apr 18, 2009 6:04 am    Post subject:
had a brain fart. you don't have the blue on. You turned off the blue when you were going through the steps.
Just press the blue button to show the color.
Adam
Benjamin Franklin
quest_enterprises
Posted: Thu Apr 30, 2009 1:58 am    Post subject:
Thanks very much. It worked great. If you are ever in the Marion Iowa area stop through to see the set up.
