Kipper
kal Forum Administrator
jkruger
| Posted: Fri Apr 17, 2009 5:42 pm Post subject: |
I run the Wii component output into a Samsung SIR T165 set top box and it seems to upscale pretty well. From there it goes into a switcher, then thru the HdFury1 to my PJ. It's great.
Kipper
| Posted: Fri Apr 17, 2009 6:19 pm Post subject: |
| kal wrote: | I may be wrong but I thought the Wii only had composite and component output? Not RGB. RGB is not component. They're different.
Kal |
Thanks KAl, I should have said component...was in a hurry and used r,g,b to describe the colours...
| Posted: Fri Apr 17, 2009 11:59 pm Post subject: |
| Kipper wrote: | | kal wrote: | I may be wrong but I thought the Wii only had composite and component output? Not RGB. RGB is not component. They're different.
Kal |
Thanks KAl, I should have said component...was in a hurry and used r,g,b to describe the colours... |
Misuse of signals like that will get yoiu banned around here.
Mr. Green
| Posted: Sat Apr 18, 2009 12:07 am Post subject: |
I tried my Wii using the component in on the box 1040, couldn't get it to give me a usable image. I'd love to put the Wii on the projector though.
| Posted: Sat Apr 18, 2009 3:33 am Post subject: |
| Mr. Green wrote: |
I tried my Wii using the component in on the box 1040, couldn't get it to give me a usable image. I'd love to put the Wii on the projector though. |
Send this issue along to x-vue (at) curtpalme.com. Mabe Juha has a solution for you.
