help marquee 9500 ultra ceiling bracket
bccole23
Posted: Tue Apr 14, 2009 4:50 pm    Post subject: help marquee 9500 ultra ceiling bracket
I need help locating the rest of a ceiling bracket for my 9500lc ultra Curt suggested i try here i have all of the parts that attatch to the prjector now i need the parts that attatch to the ceiling.[img][/img]
 Filesize:  132.86 KB
 Viewed:  8373 Time(s)
Posted: Tue Apr 14, 2009 6:55 pm    Post subject:
this is pretty common, the PJ gets pulled down but the people who do this work aren't the type to take the mating piece and attach it back together. I have gotten 3 or 4 brackets wit hjust the PJ half. Never could find the missing piece, wound up fabricating the missing piece by and machining/welding mild steel together. Basically, it's going to look like a box with slots on the upper flat part and 1 pin on the side. 4 nutes spot welded to inner face.
Clarence
Posted: Tue Apr 14, 2009 7:08 pm    Post subject:
I think I have a few of those somewhere, but I'm not exactly sure if they went to a Marquee, or a G70, or a G90, or a Barco, or a Ampro, or a XG, or a PG, or a...
What's the measured width between your hooker doohickies?
Posted: Tue Apr 14, 2009 7:11 pm    Post subject:
He emailed me, I told him I'd never seen this type of bracket used on a Marquee, as the mounting holes for the Marquee are in the extreme corners of the set.
Posted: Tue Apr 14, 2009 7:22 pm    Post subject:
That looks like the bottom half of a Sony mount, for a 12xx set.
bccole23
Posted: Tue Apr 14, 2009 7:23 pm    Post subject:
thank you for the responses. it is 3 1/2 inches between the brackets when the are screwed into the base i will try to post more pictures to help
Posted: Tue Apr 14, 2009 7:24 pm    Post subject: Re: help marquee 9500 ultra ceiling bracket
That is the part that attaches to the ceiling, you need the part that goes on the projector.
I remember seeing a bracket like that before, but not on a marquee.
bccole23
Posted: Tue Apr 14, 2009 7:25 pm    Post subject: more pictures
here are some more pictures
 Filesize:  371 KB
 Viewed:  6670 Time(s)
bccole23
Posted: Tue Apr 14, 2009 7:28 pm    Post subject:
the two ears bolt to an aluminium plate that slides in the steel bracket attatched to the projector the last picture is of the projector on it's side and the plates bolted to it
Clarence
Posted: Tue Apr 14, 2009 7:29 pm    Post subject:
Those wings are bolted on backwards... the hook tab doohickies are typically more like 18" apart.
Looks like someone rigged their own mounting contraption from other projector mounts. Not that there's anything wrong with that. Wink
bccole23
Posted: Tue Apr 14, 2009 7:34 pm    Post subject:
the plates can only bolt on one way because the holes are staggered, thank you i am open to any suggestions and i appreciate everyones time and help
Posted: Tue Apr 14, 2009 7:47 pm    Post subject:
Hello
Discard that rig, it is not bolted to the projector frame and looks highly unsafe.
bccole23
Posted: Tue Apr 14, 2009 7:51 pm    Post subject:
there is a stout frame around the edges that bolts to the frame with a narrower track that is attatched between that the aluminum plates slides in left to right
bccole23
Posted: Tue Apr 14, 2009 7:52 pm    Post subject:
does anyone know if this is a standard mount it does look prfessionaly built and is very heavy or someones home project
Posted: Tue Apr 14, 2009 8:25 pm    Post subject:
Hello
I would not never ever mount a Marquee projector by other than the foot sockets; that was the intention of the designers.
bccole23
Posted: Tue Apr 14, 2009 9:45 pm    Post subject:
that is where the bolts to this frame attatch is the foot well sockets
Mr. Green
Posted: Tue Apr 14, 2009 11:38 pm    Post subject:
Any marquee owners out there that can snap a few quick pictures of their mount?
bccole23
Posted: Wed Apr 15, 2009 1:32 am    Post subject:
any more help would be appreciated
NewbieDAN
Posted: Wed Apr 15, 2009 2:15 am    Post subject:
Get your duster out.
Posted: Wed Apr 15, 2009 3:42 am    Post subject:
Not sure how a duster will help his situation Mr. Green :
 Filesize:  28.97 KB
 Viewed:  8166 Time(s)
 Filesize:  22.37 KB
