Need help IDing a part
Posted: Wed Apr 08, 2009 11:40 pm    Post subject: Need help IDing a part
I need help IDing a diode of sorts. All it says on the Barco schematic is D400. It is shunted across a switching transformer, in series with a diode..
The schematic looks like two diodes pointing towards each other, with a zener like line between them. It says 300V, 1500W.
Part number on the diode/surge protector(?) is
CA
C132.
google comes up with nothing.
I took the diode out of circuit, it's leaky in one direction, and sure enough, the power supply powers up without it in circuit, but it looks like a surge protector/clamp of sorts, so I don't want to leave it out.
Mike Parker/Macguyver/anyone, got any ideas?
Posted: Wed Apr 08, 2009 11:44 pm    Post subject:
K, found the symbol, and I'm guessing this is what it is.
http://en.wikipedia.org/wiki/Transient_voltage_suppression_diode
Posted: Thu Apr 09, 2009 12:06 am    Post subject:
Which Barco?
Posted: Thu Apr 09, 2009 12:11 am    Post subject:
909. I've found the part at Newark. My problem was that I didn't realize that these diodes used the 1.5KE200 as a part number. I googled that, and got lots of hits.
Thanks!
Posted: Thu Apr 09, 2009 12:15 am    Post subject:
I think I actually have some of them here. Laughing
Glad you found them.
WTS
Posted: Thu Apr 09, 2009 12:24 am    Post subject:
yeap that's a transzorb, I've attached the vishay version of them but it doesn't have a 300v one but then again you don't need it to be exact.
15ke.pdf
 Filename:  15ke.pdf
 Filesize:  121.15 KB
 Downloaded:  160 Time(s)
Walter
