Center Cross hair moving (green)
sdubreuil
Posted: Tue Mar 31, 2009 1:16 am    Post subject: Center Cross hair moving (green)
Hi all
I need help here.
I was doing the ajustment on my Sony VPH-1251. While I was ajusting the center cross with the center of my screen, I have noticed that the green color was slowing moving around the center of my screen.
So the green is not stable. What is the problem with it? Laughing
Stephane
Electrogeek
Posted: Tue Mar 31, 2009 10:31 am    Post subject:
hi
here is my one suggestion (and the only reason I know this is I made this mistake the first time I played with a crt projector)
are you using a magnetic/metal screw driver to adjust the pots? - if so find a plastic one
Cheers
Andrew
I have found a use for compact fluorescents hehe
sdubreuil
Posted: Wed Apr 01, 2009 12:02 am    Post subject:
No, it is always moving. If I put a the cross hair and compare the center with the center of the screen, it is slowly moving around aound the center.
Any idea why?
Stephane
Posted: Mon Apr 13, 2009 2:18 am    Post subject:
Failing capacitors on one of the boards id say. Unless youve got a failing deflector yoke.
Does it do this right from first turn on or only after ifs warmed up?
scir16v
Posted: Mon Apr 13, 2009 4:28 am    Post subject:
Is there a phospher saver(orbit) feature that is turned on?
jask
Posted: Mon Apr 13, 2009 4:48 am    Post subject:
If it is moving slowly in one direction for the first 15 or 20 min. after startup then stays in one place it is your tubes warming up and drifting- you need to redo your setup...... If the image is oscillating then you have electronic problems.
Posted: Mon Apr 13, 2009 5:49 am    Post subject:
My 1252 did that just before it gave out.
Mr. Green
Posted: Mon Apr 13, 2009 5:50 am    Post subject:
I thought you still had the 1252? Did you fix it? If yes, what was broken?
Posted: Mon Apr 13, 2009 5:51 am    Post subject:
I still have it ( like I get rid of anything ) I just never got to fixing it. I started a car restoration and that was that. Wink
