dturco
| Posted: Thu Mar 26, 2009 5:47 pm Post subject: Lense Scratch |
Can a small scratch on the red lense cause a red "bloom" on the screen? Right side only.
http://www.hulu.com/firefly
| Posted: Thu Mar 26, 2009 6:07 pm Post subject: |
A "small scratch" on the outside of the lens should not cause anything like "bloom", nor even be visible on-screen at all for that matter.
To be noticeable, you'd need many scratches, or a large abrasion, and even then, it would show up as an area of lower resolution and lower contrast... lighter darks and darker lights and not quite as sharp... and being only on one lens, the effects would be subtle - not obvious.
Bruce 09
Joined: 08 Mar 2006 Posts: 747 Location: Kamloops BC, Canada
| Posted: Thu Mar 26, 2009 6:32 pm Post subject: Re: Lense Scratch |
| dturco wrote: | | Can a small scratch on the red lense cause a red "bloom" on the screen? Right side only. |
It is another problem than a slight front lens scratch! What projector, what lens ? Did you turn contrast down and look in the lens ? Did you go check Clarences out yet ? What are you doing in Boca ?
Bruce
Clarence
dturco
| Posted: Thu Mar 26, 2009 6:39 pm Post subject: |
What a lot of questions. 9500L/C marquee lense unknown.
Not yet I will look in when I get back to Maryland.
No Clarence and I have not hooked up yet.
Thinking about relocating near relatives in boca.
Thanks for being interested.
dturco
| Posted: Thu Mar 26, 2009 6:44 pm Post subject: |
Holy monkey butt batman. Clarence that is amazing. So It sure looks like something else. Maybe a gamble but I think I am buying this one. I think it is just dirty and needs tweaking then.
Clarence
| Posted: Thu Mar 26, 2009 7:25 pm Post subject: |
The bloom could be "fungus" in the glycol of the red tube.
Or it could just be bad stig, bad schiempflug, or bad EM focus.
dturco
| Posted: Thu Mar 26, 2009 9:39 pm Post subject: |
Clarence are these things an easy fix?
Clarence
| Posted: Thu Mar 26, 2009 10:08 pm Post subject: |
Fungus requires draining glycol, washing out the chamber with CLR, then refilling with new glycol. Not easy. But not impossible.
Stig, scheimpflug, and focus are basic setup steps... easy to get to the 90% solution (enough to get rid of fuzzy blooming), but it takes skillz (or a pro) to get it almost perfect.
dturco
| Posted: Thu Mar 26, 2009 10:28 pm Post subject: |
Well I got mad skills. See 2+2=4. I did see some Blobs at the bottom of the lenses looked like cottage cheese. Fungus? I'm talking, very small more like specs but something is there.
