NewbieDAN
Joined: 09 Mar 2006 Posts: 319 Location: Bunbury Western Australia
| Posted: Mon Mar 23, 2009 2:12 am Post subject: Can someone explain Gamma on the BarcoGraphics 1209s to me? |
I've got a BG1209s and am interested in the internal gamma adjustment, there is no information I have found, has anyone had a play with this. I believe the G90 has this adjustment also.
_________________ Sorting the fly sh*t from the pepper
Elaine Benes
| Posted: Mon Mar 23, 2009 2:16 am Post subject: Re: Can someone explain Gamma on the BarcoGraphics 1209s to |
| NewbieDAN wrote: | | I've got a BG1209s and am interested in the internal gamma adjustment, there is no information I have found, has anyone had a play with this. I believe the G90 has this adjustment also. |
It's not gamma like you're thinking its gamma, it isn't applied to the external source, its just a variability option for smoothing out the white balance curve when you're doing colorimetry. You shouldn't adjust it unless you have a colorimeter to measure the effect on your greyscale.
It is explained a little in the 808s Owners manual, I think I saw it there today, I'm sure it will be very similar to the gamma in your bigger machine.
