moome
| Posted: Fri Mar 20, 2009 3:56 am Post subject: Re: moome vin-full hd rgb bypass |
| fishlogan wrote: | ive got a new moome card and the pic is great
only problem is that when i set it to rgb bypass mode, every time i turn of my projector it resets back to active dvirgb mode
is there any way to make the setting stick each time i powerdown then back up again? |
hi:
the rgb bypass mode is for professional user to test,so i don't set the model for normal model
if it is really confused you, you can sent it back for me,i will update for you.
Moome
