lukem
| Posted: Sun Mar 15, 2009 11:03 am Post subject: new build- blu ray playback grief |
just got myself new motherboard and graphics card and still cant get blu ray playback.
spec:
MO: asus m2n68 AM+ or AM2
cpu: AMD 7750 64
power :550w
graphics card: asus geforce 8600gt
blu ray player : lg ggc h20l.
if anybody can help on this issue i would be much appreciated.
i have tried
powerdvd 8/9
home theatre software..
nero 9
Anydvd
all i get is "no disc in drive"
pls help me
| Posted: Sun Mar 15, 2009 12:41 pm Post subject: |
Does it work with regular DVDs / CDs?
| Posted: Sun Mar 15, 2009 1:04 pm Post subject: |
Maybe your moter board's SATA controller doens't like the drive or vice versa. How do you have teh SATA controler set in the BIOS? Do you have Raid disabled?
lukem
| Posted: Sun Mar 15, 2009 1:05 pm Post subject: |
i have got a little futher now.
i have 2 drives which it detects
both LG one is a dvd-rw and the other is my GGC h20l
when i put the dvd in the normal drive it will play,
but in the blue ray drive it doesnt seem to load properly or just hangs..
any ideas?
lukem
| Posted: Sun Mar 15, 2009 1:41 pm Post subject: |
if i put a normal dvd in th blue ray drive is says "no disc in drive E"
but if i put it in normal dvd drive powerdvd will play it but just not in blu ray drive
jkruger
| Posted: Sun Mar 15, 2009 3:15 pm Post subject: |
Mine used to do the same thing. AMD chip, 8600gt, ggc-h20l. I did a firmware update and downloaded the newest drivers. It seems to work okay now.
lukem
| Posted: Sun Mar 15, 2009 3:26 pm Post subject: |
i am unable to connect to internet on desktop at the moment, are you able to send me this update, or is it installed automatically.?
jkruger
| Posted: Sun Mar 15, 2009 3:29 pm Post subject: |
If you can't connect to the internet right now, how are you accessing this forum?
lukem
| Posted: Sun Mar 15, 2009 3:38 pm Post subject: |
via my laptop which does have internet.
problem is that i have just bought a new dongle for desktop as old one doesnt have any drivers for vista.
jkruger
| Posted: Sun Mar 15, 2009 3:40 pm Post subject: |
Can you download to a flashdrive and put them on the desktop machine?
lukem
| Posted: Sun Mar 15, 2009 3:47 pm Post subject: |
i have a usb stick.
i have been looking to find the firmware updates on LG site but cant find them, would be much appreciative if you could send me firmware updates, and then i can try it out and if i still have problems get back to you guys.
jkruger
| Posted: Sun Mar 15, 2009 4:05 pm Post subject: |
A google search turned up lots of stuff: http://forum.slysoft.com/showthread.php?t=19080
You might want to do some reading first.
My htpc has a firmware update icon that I used to update with.
lukem
| Posted: Sun Mar 15, 2009 4:13 pm Post subject: |
i have the icon on the desktop where i installed the drive, but desktop is not connected to internet.
main problem is that when i put a dvd or blu ray in drive it just says there is no disc in drive.
this problem has been bugging me for ages
lukem
| Posted: Sun Mar 15, 2009 4:16 pm Post subject: |
Anydvd tell me i have version 1.03 firmware installed.
| Posted: Sun Mar 15, 2009 4:17 pm Post subject: |
If you are running XP have you tried installing a UDF file system driver?
lukem
| Posted: Sun Mar 15, 2009 4:21 pm Post subject: |
no i am running windows vista.
| Posted: Sun Mar 15, 2009 4:35 pm Post subject: |
I think Vista has that driver built in from what I remember reading.
This again makes me wonder about the SATA chipset on the mother board. I know with my LG HDDVD/BR combo drive the firwst board I had didn't work with it. I had to use a SATA to USB cable.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=120.html
Also go into your BIOS and see how the SATA controller is set up. If you aren't comfterable in the BIOS don't change anything! You can make your PC not boot. Just look and exit without saving.
lukem
| Posted: Sun Mar 15, 2009 4:50 pm Post subject: |
i have checked that the sata is set to sata mode which it is.
thought that blu ray needs to run of sata and not Ide?
lukem
| Posted: Sun Mar 15, 2009 5:47 pm Post subject: |
still no joy.
not sure what to do now.
| Posted: Sun Mar 15, 2009 11:12 pm Post subject: |
| lukem wrote: | still no joy.
not sure what to do now. |
Did you have a SATA plain-ol-DVD drive in there before that worked? If not, maybe try finding a SATA DVD drive, see if it's an interface / mobo problem or a drive problem.
