Can't get Moome board to work correctly with Sony D50
uwanna
Posted: Thu Mar 12, 2009 9:50 pm    Post subject: Can't get Moome board to work correctly with Sony D50
My Sony G70 just broke, and I rolled in my old Sony D50 in it's place. I took the Moome DVI board out of the G70, where it worked perfectly, and plugged it into the D50. I just doesn't work right. When hooked up to DVI it lights up all three light on the Moome, but when I try to configure the B input to either HDTV Y Pr B, or HDTV RGB, it says "no input". (can't recall which HDTV mode worked with the G70, but one did) Only method to get any picture is to hook up w/component cable and config to RGB. Any ideas? HELP!
Posted: Fri Mar 13, 2009 1:03 am    Post subject:
Check the dip switches... I could have sworn there was a setting for what kind of Sony you have on Moome's older cards.
I don't have the manual here - we came on board after Moome had already gone HDMI.
uwanna
Posted: Fri Mar 13, 2009 2:11 pm    Post subject:
Checked the plugging of the "switches". J1,J2,J3. My board is plugged for J1 which is the setting for D50, G70,and G90. J2 & J3 are for older 12xx series projs.
Still can't figure out what the problem could be. On both input B HDTV settings with DVI connected, it shows no input, but works with plain RGB setting with component cables.
What is the switch on the faceplate for? Makes no difference what position it's in.
Just don't understand why it works with my G70 but not D50. Help!
