| Posted: Thu Mar 12, 2009 4:16 am Post subject: Has anyone tried replacing a raw tube in a 1292? |
So I have a good set (or two) of BArco 1200 tubes, which are the same tubes as used in a 1292 or Ampro 4200. I can take the glass tubes out of the Barco housing no problem, but haven't ever ripped apart a 1292 tube to see if it comes out as easily.
Has anyone tried, or should I take pix of the process (and the glass shards in the eye!) for everyone to follow along?
1031
Ile
| Posted: Thu Mar 12, 2009 8:43 am Post subject: |
It was similar work to get tube out of 1292 housing, no problem. I still have 1292 housing, so I can take picture of glued surfaces if that help.
1292 09MFX3 tubes have 14 mm longer neck what BG1200 09MX/09MI tubes. Other dimensions and pin out is same, but BG1200 tubes had some pins cutted. So check first are 1292 neck board using those cutted pins.
| Posted: Thu Mar 12, 2009 2:25 pm Post subject: |
thanks for that, I'll try it this weekend.
| Posted: Fri Mar 13, 2009 9:39 pm Post subject: |
Graham has done it lots of times.
He just smashes the old tube out.
Don't rip the metal bellows.
Ile
| Posted: Sat Mar 14, 2009 1:42 pm Post subject: |
Sides are easy to cut from outside, but top and bottom have heatsinks in front of glued seam so I cutted those from inside.
