Disassembling HD10?
vespaman
Posted: Sun Mar 08, 2009 11:46 am    Post subject: Disassembling HD10?
A few years back, I got hold of some GT17 lenses, with a lot of dust on their lenses - both outside and inside, which I substituted with the stock lenses on my 9500LC after cleaning them outside.
Well, while I am not sure that there will be any noticable difference, should they have been clean, but I find that I don't enjoy seeing all that dust on the inside while looking at the projector when it is running...
So, the other day, after I installed my new Moome hdmi 1.3 card into the set, I was thinking about a serious cleaning of the lenses by taking them apart.
But maybe this needs special tools, of some sort. If not, is there something to stop me from having a go at it?
Someone done this op? (I'm sure some of you must have done this! Very Happy )
Cheers,
Micael
Posted: Sun Mar 08, 2009 12:17 pm    Post subject:
I started to, i took off the bottom lens and think i am going to try to swap it with a HD10L or HD10 lens and see what happens, it might focus it might not. but here is my post on it.
http://www.curtpalme.com/forum/viewtopic.php?p=174280#174280
You do mess up the soft aluminum doing it though.
1031
Posted: Sun Mar 08, 2009 12:23 pm    Post subject:
I have opened those lenses (plain hd-10īs) Front and rear lenses are quite easy, there is big ring around lense that has threadīs on it. there is place for tools so you can turn that ring and open lense. Those ringīs are usually quite tight so i heated outer barrel little with hairdryer and sprayed coolspray to that ring part.Then with big flathead srewdriver and small hammer i started to tap those open...It would be easy if someone helps to hold that barrel while tapping that ring open, also if someone taps opposite side of ring same time. First half turn is hardest part after then its easy.. But if dust is between front lenses then try open those "guide screws" that are on those grooves that move lensebarrel. those are usually locked with "locktite" so little heat helps to open those. After that itīs easy to pull front barrel out.
Hammer & screwdriver & hd-lenses-> be carefull Mr. Green
Edit: Joust had special tool for removing those "guide screws" ->
http://www.curtpalme.com/docs/HD144_lens_adapter_kit_MKII_Instructions.pdf
DVDO VP-50
New hobby, Rally
Posted: Sun Mar 08, 2009 2:45 pm    Post subject:
While I suppose there is some chance of dust getting in between the front and back half of the lens assembly, there should be no reason to seporate the front or rear lens packs. I have completely dissassembled lenses before and trust me when I say "you don't want to do it". If I were you, I would go no further than removing the front barrel from the rear and only clean that area. Unless you have a "clean room" you will probably do more harm then good.
vespaman
Posted: Sun Mar 08, 2009 6:36 pm    Post subject:
OK, thanks Guys! I guess I will mostly do the basic stuff to my GT17's, but I'll inspect the lenses more thourogh to see where that dust/durt/smoke is is actually located, and concentrate on that particular area.
I have my old HD10L to practice on.. Smile
Is there any exploded views on HD10 floating around?
Posted: Sun Mar 08, 2009 6:41 pm    Post subject:
there is a document in the all about lens thread that has a diagram that would be similar to how a lens is put together, i think there may be close to 10 elements in the HD10's but this is just a guess.
Posted: Sun Mar 08, 2009 6:46 pm    Post subject:
Remember when you take it apart to indicate which side the lens element is suposed to be facing.
vespaman
Posted: Sun Mar 08, 2009 7:10 pm    Post subject:
10 elements! Hehe. Silly me, I thought it would be something like 4... Smile I'll be careful for sure!
Posted: Sun Mar 08, 2009 7:22 pm    Post subject:
Nice lens spanner wrench but I hope you know what your doing !
http://www.calumetphoto.com/item/ES1000/?t=GB01&a=CA01&CAWELAID=36796370
The spacing of the elements is also critical Wink
Posted: Sun Mar 08, 2009 7:29 pm    Post subject:
Man that would come in handy!!! but 106 bucks? I think my screw driver method and some sweat was ok for now.
Posted: Sun Mar 08, 2009 7:36 pm    Post subject:
You can find a better price but you get what you pay for...
http://www.shopping.com/xGS-Lens_Spanner~NS-1~linkin_id-8000680
One slip with the wrench and possibly a nasty scratch on the element.
Second thought don't even go there ! Shocked
Way to easy to screw up !
Posted: Sun Mar 08, 2009 7:51 pm    Post subject:
this looks like a nice set and not to expensive:
http://www.skgrimes.com/span/index.htm
But after taking the bottom lens off on the HD10GT 17 there is no way you can do it with that and hand strength alone. maybe start with a hammer and driver then move to the spanner wrench.
Posted: Sun Mar 08, 2009 7:53 pm    Post subject:
I bought one myself. Nice span wrench Smile
