ac/dc
| Posted: Sun Mar 08, 2009 12:25 am Post subject: Hooking Up A DVD Player |
I'm looking at buying a new DVD player for my 1272 sony. Never used on before with a projector. What is the best way to hook one up to the projector? I'm thinking of a blue ray unit. Thank You
MikeEby
| Posted: Sun Mar 08, 2009 12:47 am Post subject: Re: Hooking Up A DVD Player |
| ac/dc wrote: | | I'm looking at buying a new DVD player for my 1272 sony. Never used on before with a projector. |
Dude what the heck were you using VHS? Man you are in for a treat with blu-ray. Here is a link to a semi used HD Fury for $100.
http://www.curtpalme.com/forum/viewtopic.php?p=177604#177604
You can also buy a new one on this site too for a few more $$$.
http://www.curtpalme.com/HDFury.shtm
The Fury is probably the best way to go with a 1272, set your blu-ray player to 1080i set it up and enjoy.
ac/dc
| Posted: Sun Mar 08, 2009 1:01 am Post subject: |
I had a JVC dvd recorder on my regular tv, but it died early on. Haven't been using anything. I'm thinking of just buying a player right now.
Do I have to use that Fury connector? Cost more than the players I've seen.
MikeEby
| Posted: Sun Mar 08, 2009 3:15 am Post subject: |
You might be able to find a used component to RGB transcoder but it probably won't be much less. Then you won't be able to upscale DVD's to 1080i, they would be stuck at 480p.
If you want to upscale your DVD's past 480P ( which I would recommend ) then yes you'll need the HDFury with the power supply.
The one for sale in the Buy and Sell forum doens't have the BNC RGBHV cable. You may be able to get away with using a 6 foot VGA to RGBHV cable and a gender changer but your picture may suffer a little.
You would be better off with the HDFury1 advanced kit with the green edition RGBHV cable and power supply.
Your hook up would be as follows: DVD----HDMI.to.DVI.cable----HDFury1===RGBHV.BNC.cable==Sony projector.
This will get you 1080i
If you don't go for the HDFury then your DVD's will only be 480P and you'll still need a Component to RGBHV transcoder and a cable to get the video to the projector.
Kim's RTC2200 is an awesum transcoder at just $189, http://www.curtpalme.com/RTC2200.shtm
Or if you want to save a little money you could go for the Box1040 Lite. You can buy it here for $149, http://www.curtpalme.com/Box1040.shtm
You would hook the transcoder up as follows:
DVD===component.cables====Thanscoder===VGA.to.RGBHV.cable====Sony Projector.
This will get you 480P
| Posted: Sun Mar 08, 2009 3:16 am Post subject: |
ac/dc
| Posted: Sun Mar 08, 2009 4:07 am Post subject: |
I see some HD Fury's on Amazon.com that are cheaper than converters. Thanks guys, I'll give one a try.
MikeEby
| Posted: Sun Mar 08, 2009 4:29 am Post subject: |
In most cases you will need the power supply, make sure you get one with the package you buy.
| Posted: Sun Mar 08, 2009 7:23 am Post subject: |
| ac/dc wrote: | | I see some HD Fury's on Amazon.com that are cheaper than converters. Thanks guys, I'll give one a try. |
I just looked at the one on Amazon. No where does it say you get a power supply.
You will need it too. Also doesn't include the HDMI to DVI cable. So figure power supply from Radio Shack $36, HDMI to DVI cable $12 ( for a decent one ) + the $120.13 for the HDFury
you can order the whole advanced kit here for $149 USD deliverd 2-5 days world wide, and have a turn key-ready to go solution.
It includeds the HDFury1, RGBHV breakout cable, power supply and a 6' HDMI to DVI cable.
All you have to do is select the proper RGB extender cable ( Green edition ) 5 BNC breakout and the proper power supply for your country.
ac/dc
| Posted: Tue Mar 10, 2009 12:02 am Post subject: |
I don't need a HDMI cable.
Just curious, Do you get commission on sales here?
Mr. Green
| Posted: Tue Mar 10, 2009 12:08 am Post subject: |
Nope, no commissions. We just support this site. Besides, everything is reasonably priced here.
Also, if you have any trouble, there's loads of help here.
ac/dc
| Posted: Wed Mar 11, 2009 4:01 am Post subject: |
My question was for analog rock
| Mr. Green wrote: | Nope, no commissions. We just support this site. Besides, everything is reasonably priced here.
Also, if you have any trouble, there's loads of help here. |
