Need help with Sony G90 firmware upload program
Posted: Thu Mar 05, 2009 11:51 pm    Post subject: Need help with Sony G90 firmware upload program
So I am playing around with a couple of G90 Ya boards. I managed to nuke one, I'm so pissed that I won't even post about it. (it wasn't working right, now it's not working at all!).
Anyways, what I want to do is upload new firmware to the other Ya board that I suspect has a bad IC421, but want to make sure it's not a firmware issue.
I got the firmware upload program working just fine, it sees the projector, etc, but the program doesn't see the firmware file that I've got on CDROM. I select D drive (CD ROM) in the menu, but the program can't see it.
What am I doing wrong?
Posted: Thu Mar 05, 2009 11:56 pm    Post subject:
What is the file format? Is it a bin file?
Posted: Fri Mar 06, 2009 12:05 am    Post subject:
No, it's a .pjv file. Here:
http://www.curtpalme.com/SonyG90_Downloads.shtm
Posted: Fri Mar 06, 2009 12:08 am    Post subject:
Can you copy that file to your C drive or desktop and see if the program can recognize it from there?
Posted: Fri Mar 06, 2009 12:29 am    Post subject:
Curt....I'm looking over those files and the actual flash files are the MOT files. There are 2 of them...1 for ic234 and 1 for ic534. It says the pjv file is just the PC application.
Posted: Fri Mar 06, 2009 12:36 am    Post subject:
Maybe try copying the 2 MOT and 1 PJV files into the working directory...........C:\ , program files , PJUpdate.
Posted: Fri Mar 06, 2009 1:03 am    Post subject:
I thought I tried that, but I'll give it a shot. Turns out that Haydn's Ya board that I was going to flash doesn't have a firmware problem anyways, so I'll send it to CIE to try and repair it. I think his problem is IC 421 related as well, in fact I'm sure of it.
Posted: Fri Mar 06, 2009 4:30 pm    Post subject:
Curt, I always put the FW in the root right on the C: drive. I'll attach the FW files just in case you don't have the right ones.
Posted: Fri Mar 06, 2009 4:40 pm    Post subject:
Looks like the forum doesn't like the files or the are too big. Here are links to them.
http://www.cir-engineering.com/bin/uv111.zip
