Ohmess
| Posted: Thu Feb 26, 2009 11:33 am Post subject: Marquee internal frequencies |
Is there a single internal frequency for the Marquee that is best for video or should I be using different frequencies for different sources?
| Posted: Thu Feb 26, 2009 11:53 am Post subject: |
The internal frequencies are really only there to help converge your PJ to a known similar external frequency if you don't have a grid pattern you can use from your source. It also helpful for diagnosing problems on your boards using a scope or multi meter( like testing the band switch from the clm to the FCM ,HDM,and VDM). For 1080p i use #5. It doest matter were you leave it because it switches automatically to your external source frequency once its in use.
| Posted: Thu Feb 26, 2009 6:03 pm Post subject: |
Hello
The 31khz internal dot pattern lets you see larger dots for stig and flare alignments, but you do not need to "set" a frequency for anything.
