ben12345
| Posted: Tue Feb 24, 2009 1:33 pm Post subject: Barco 800 Bad focus block? |
I've just got my Data 800 set up the way I want (showing Sky HD at 1080i) and now i've got a problem:
My blacks keep going blue or red, so I have to keep turning down the G2 adjustment for the relevant tube, and then turning up the gain. Each time I adjust it, it might last 5-10 hours, before my blacks aren't black anymore.
Problem is now, that when there is a bright area on the screen, such as a menu bar or credits, then this bright area creates a horizontal bar across the screen of that colour. It only seems to happen for the blue and red, so i'm guessing this has to do with the lower grid voltage, as a result of turning down the G2 controls.
Is this an indication of a bad focus block, or is there more to it?
Ben
| Posted: Tue Feb 24, 2009 2:41 pm Post subject: |
It could be, but I'd suspect your video output boards. I've got all parts in stock for cheap for the 800.
ben12345
| Posted: Tue Feb 24, 2009 4:55 pm Post subject: |
Thanks Curt,
Is that what they refer to in the service manual as the 'RGB Output module'? or the 'Quad decoder and RGB amplifier'?
Seems strange that it started happening on two tubes at the same time. Although I did notice that the blue needs more frequent tweaking than the red.
Cheers,
Ben
ben12345
| Posted: Tue Feb 24, 2009 6:05 pm Post subject: |
Tom,
That looks exactly like my problem! I'd better get those FETs on order asap and avoid using the set in the meantime.
Thanks for your help,
Ben.
| Posted: Tue Feb 24, 2009 6:25 pm Post subject: |
The bastard FET from hell !
