Contrast Modulation for Barco 1209s/E
Gary M.
Posted: Sun Feb 15, 2009 1:40 pm    Post subject: Contrast Modulation for Barco 1209s/E
which contrast modulation does a guy need for the Barco 1209s/E?, mine is a Runco 1101 but that doesn't matter I don't think
I have purchased a contrast mod kit that is a small board a little bigger than the HDTV add-on, but the wiring harness doesn't match the connector on the quad board (R762637), the contrast mod board is R7624845 from a 909
do I need the port 3 contrast mod or what do I need?
thanks a bunch
-Gary
Gary M.
Posted: Sun Feb 15, 2009 1:54 pm    Post subject:
problem solved, I looked at Kals Zenith pics and explanation, it seems there is 2 places for contrast modulation, so I pulled my RGB driver and low and behold there is the connector (labeled contrast modulation option) and standoffs for the board I have
yippee!
why is there 2 places to connect contrast mod on the Barcos? one at the RGB driver with 12 pin connector and one at the sync/vert def with 10 pin connector?
-Gary
