Why no adjustments????????????
htmike
Posted: Mon Feb 09, 2009 1:16 am    Post subject: Why no adjustments????????????
Well after a long struggle with wiring for blu ray, i feel i'm back at square one!!!!
I am now running a Sony ps-3 with an hdmi line out to a moome EXT box then rgbhv out to the e-home 8110 projector's rgbvh input.
The only adjustments I have is brightness and contrast on the projector and the gamma adjustments on the moome ext.
How do i control any other settings?? eg color tint sharpness etc etc??
I've been trying to get the colors on for the past 2 days with only these 3 options but i've had no success.
any advise would be greatly appreciated
Posted: Mon Feb 09, 2009 3:38 am    Post subject:
You don't adjust color/sharp/tint/etc with RGBHV. Those only apply e.g. to NTSC. To get the colors & sharpness right with an NTSC feed you calibrate your projector. (See Kal's amazing guide at https://www.curtpalme.com/forum_archived/viewtopic.php@t=10457.html)
FWIW I have almost the identical setup: PS3 -> EXT-HD -> 8500. Get the projector set up right -- the results will rock you!
Posted: Mon Feb 09, 2009 4:05 am    Post subject:
Mike you need to do grey scale, those setting on the remote are only if you have the Multi standard decoder installed above the VIM. that is basicly all 480i signals. Follow Tim Martins Guide here to get you started, then do as gary suggests and get an Eye one probe and use the free HCFR program or use Calman.
http://www.etechvideo.com/techtip1.htm
