Question about the R762173 Barco board
Corleone88
Posted: Sun Feb 08, 2009 5:41 pm    Post subject: Question about the R762173 Barco board
I plan to change my actual neckboards (R7621735) on my BG808 by the R762173 (no ABL) boards to try to get rid of the streaking problem. Is it safe? Do I need to change or adjust something after the replacement?
Ile
Posted: Mon Feb 09, 2009 8:29 am    Post subject:
It's safe.
You need to adjust G2 and turn ABL pulse off from vertical board.
Corleone88
Posted: Mon Feb 09, 2009 9:35 am    Post subject:
Thanks Ile. I read somewhere that the R762173 boards may have no protection against some possible tube failures (shortage or something like that). Is it true ?
Posted: Thu Feb 12, 2009 8:43 am    Post subject:
I believe these boards are safe from spot burn. Its the even earlier RGB amps that you would not use that had no protection.
