Panasonic TV Calibration, "All Drive""All cuf
benelli125
Posted: Mon Feb 02, 2009 10:35 am    Post subject: Panasonic TV Calibration, "All Drive""All cuf
Hi there
First of all thanks for the excellent guide.
Finally I can try to calibrate my Plasma Panasonic TV (model 37PV60E similar to 37PX60E) that has a "warm" aspect since I bought it two years ago.
I have also the Service Manual and I can confirm that Panasonic uses "R-Cut off" "G-Cut off" "B-Cuf off" controls as the " RGB lowend" and "R Drive", "G Drive", " B Drive" as "RGB HighEnd" described in the Calibrating Guide for Dummies.
The Service Menu have also two more controls: " All cut-off" (default 128) and " All Drive" (default 255).
I do not know if and how I have to set this values during calibration of the TV (the guide refer only to the RGB Lowend and RGB HighEnd settings).
Any suggestion from people who already calibrated a Panasonic Plasma TV?
Best ragards
benelli 125
Pulse1
Posted: Mon Feb 02, 2009 4:49 pm    Post subject:
I would leave the All cuts and drives alone as well as the Green cut and drive. Just adjust the Red/Blue cuts and drives and remember to store your new settings, It's always a good idea to write down the settings before you make any adjustments incase you make it worse Thumbs Up
Cheers
Brian
