ffdshow with mkv's or EVR renderer?
benareeno
Posted: Mon Feb 02, 2009 6:27 am    Post subject: ffdshow with mkv's or EVR renderer?
Seems to me that the EVR renderer makes a much nicer pic than any of the others...I can't even imagine the need for any sharpening or denoise.
Are all of you using evr or something different + ffdshow?
The last few 720p mkv's looked really, really good through evr. Although it might tear a tad more than vmr9 renderless...I'm still not sure if that's the case.
Posted: Mon Feb 02, 2009 10:07 pm    Post subject:
Typically I use Haali Renderer.
I can't see any difference between them, but Haali is smoother.
I do the RGB conversion (with High Quality ticked) in Ffdshow, and am watching 1080p material (downscaling HD material is immoral)on a 1920 x 1080 resolution which means the renderer is basically a passenger for sharpness/scaling etc.
Use the Reclock tearing test to check for Tearing.
benareeno
Posted: Tue Feb 03, 2009 5:29 am    Post subject:
Never really tried Haali...but I will try it next.
I'm pretty confident that the MPC-HC's anti-tearing setting will work fine...it's just that when I'm messing around, I need to jump forward and backward through the movie. If I watch a movie start to finish, I'll use the anti-tearing setting...
Now...let's see this Haali renderer.....
