incova
| Posted: Mon Feb 02, 2009 4:05 am Post subject: Using a HTPC for Active Area Scanning, software Needed? |
Hi guys simple question, what would I need, I have playback software I just need to know whats needed for Active Area Scanning, Powerstrip, Reclock, both?
feel free to tell me the easiest way them use them as well !! thanks.
the less I know.
MikeEby
| Posted: Mon Feb 02, 2009 4:23 am Post subject: Re: Using a HTPC for Active Area Scanning, software Needed? |
| incova wrote: | Hi guys simple question, what would I need, I have playback software I just need to know whats needed for Active Area Scanning, Powerstrip, Reclock, both?
feel free to tell me the easiest way them use them as well !! thanks. |
You might want to ask in the HTPC forum but anyway. What video card are you using? I tinkered all weekend with an Nvidia 9800GT trying to get scan rates in multiples of 23.976hz with no luck. So I'm going back to ATI. The problem with ATI is the driver I was using will not allow PowerDVD to stretch far enough for the aspect ratio program to work correctly. ATI did just released Catalyst 9.1 so I will install the ATI card back into the HTPC and test with the new driver.
| Posted: Mon Feb 02, 2009 4:23 am Post subject: |
Powerstrip and Mikes masking software would be a good start ( again see the stickey in the HTPC forum ).
incova
| Posted: Tue Feb 03, 2009 1:44 am Post subject: MikeEby |
Hey Mike, I have the integrated gpu mother board Ati chipset, AMD 780g chipset, so far everything has been superstable with xp and sp3 installed. Hopefully ati will sort it all out.
the less I know.
