HDMI to HDMI gamma boost box?
Erik dP
Posted: Sat Jan 31, 2009 5:35 pm    Post subject: HDMI to HDMI gamma boost box?
Are there any HDMI to HDMI gamma boost boxes out there?
All I have seen is gamma boost on analog signals.
I have a HDMI input card in my SONY 1272 and would like to do the gamma boost before the PJ.
Gino
Posted: Sun Feb 01, 2009 12:56 am    Post subject:
I'm not familiar with the Sony HDMI input cards, but I thought that they would have gamma bump options available like the Marquee cards?
It almost sounds like you are asking for a device which accepts HDMI in from your sources, applies the gamma adjustments, then outputs via HDMI into your Sony's HDMI input card. If this is what you're asking for, you'd need to invest in the Lumagen VP's.
Posted: Sun Feb 01, 2009 1:32 am    Post subject: Re: HDMI to HDMI gamma boost box?
Which Sony HDMI input card do you have? As far as I know, Moome's the only guy who ever made Sony CRT projector HDMI input cards and they've all had Gamma boost built in.
Erik dP
Posted: Sun Feb 01, 2009 10:00 am    Post subject:
Oh. I thought this one was wery well known:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=5147.html
From JohnHWMan
Sony DVI/HDMI (HDCP) IFB Input Card (Model: IFB-DVI-V2)
lordcloud
Posted: Mon Feb 23, 2009 11:47 pm    Post subject:
I would love to have one of these too. I don't have a projector, I have a RPCRT set with an HDMI input.
Posted: Tue Feb 24, 2009 3:37 pm    Post subject:
From JohnHWMan
Ah yes - John's card. It's DVI only. No gamma boost. Sold out years ago. The original HDFury1 was based on the design of this card. (John designed the HDfury1).
Posted: Tue Feb 24, 2009 3:39 pm    Post subject:
So to answer the original question, I've never heard of an HDMI in/out gamma booster other than expensive scalers (the RadianceXD comes to mind). You're probably not looking at spending $4000 however.
Your cheapest solution would be to sell your current card and upgrade to Moome's IFB-FULLHD. It's a much higher end card too (sharper, better colours, less noise, etc.). Plus gamma of course. And two HDMI inputs.
See: www.curtpalme.com/IFB-FULLHD.shtm
David_Web
Posted: Tue Feb 24, 2009 4:42 pm    Post subject:
Do note that you will get horrible banding in doing so as it is in 8bit digital domain.
Doing what Kal suggested is the way to go IMHO.
Or do it in the analogue domain.
Posted: Wed Feb 25, 2009 7:32 am    Post subject:
If you are skilfull enough do what i did back then when i had 1272, put "analog gamma box" inside projector. I had Johnīs IFB-Dvi card (that outputs RGBHV signal) and Under that card slott was enought room to fit TSEīs gamma card.
DVDO VP-50
New hobby, Rally
Erik dP
Posted: Sun Mar 08, 2009 4:31 pm    Post subject:
Thanks.
I thought of doing a gamma fix after the HDMI card. However, I am showing everything from the computer now and it has gamma boost.
Maybe buying the DVI card was a mistake in my case as I didn't buy a Bluray-player. I havn't really compared the RGB to the HDMI input. Oh well. It wasn't that expensive.
