Juvental604
| Posted: Tue Jan 27, 2009 6:11 am Post subject: How to get rid of thin black line through the red tube? |
Hello I have a nec pg6 projector and recently moved to a new apartment. I setup the projector again and noticed that theres a thin horizontal line going right through the middle of the red tube. Anyone know what this could be and how to remove it?
Brooklyn
Joined: 17 Sep 2007 Posts: 494 Location: Morgan Hill, CA
| Posted: Tue Jan 27, 2009 9:01 am Post subject: |
Does it appear on test patterns as well as the source?
kschmit2
| Posted: Tue Jan 27, 2009 9:30 am Post subject: |
back off your keystone or linearity settings.
Ideally: start your setup from scratch, starting with mechanical setup
Jesse S
| Posted: Tue Jan 27, 2009 8:04 pm Post subject: |
99% it's linearity balance on the red. If you set the top to + and the bottom to - values, it "pulls" the image apart. Set both back to neutral.
Juvental604
| Posted: Wed Jan 28, 2009 11:02 am Post subject: |
| Jesse S wrote: | | 99% it's linearity balance on the red. If you set the top to + and the bottom to - values, it "pulls" the image apart. Set both back to neutral. |
thanks that fixed it right up
