Parts Help Needed -- Terminal Block
Ohmess
Posted: Sat Jan 24, 2009 9:53 pm    Post subject: Parts Help Needed -- Terminal Block
Hi All -- I found a Furman PS-8R power sequencer on thebay for $25, but the circuit that sequences the powered outlets needs to be repaired. I think the transformer that powers the circuitry is shot and that it will be simple enough to fix, but I have another issue.
The sequencer can be initiated with a 12v signal, and I plan to use this, but the small block that plugs into the back of the unit did not come with it. Does anyone know where I might find one of these? Here's a picture of the item I'm seeking. Its the green block protruding from the back of the unit between the outlets:
Posted: Sat Jan 24, 2009 10:42 pm    Post subject:
THat is called a Phoenix connector. Any good electronics parts place will have that. Or try www.newark.com or www.mcmelectronics.com, etc.
fuzzybee
Posted: Sun Jan 25, 2009 10:29 am    Post subject:
ygpm
fuzzybee
Posted: Thu Feb 05, 2009 4:32 am    Post subject:
Did either of those phoenix blocks I sent you work?
Ohmess
Posted: Thu Feb 05, 2009 1:52 pm    Post subject:
Yes, problem solved.
Thanks a ton.
fuzzybee
Posted: Fri Feb 06, 2009 1:27 pm    Post subject:
Cool. Glad it worked for you.
dadude712
Posted: Sun Mar 27, 2011 11:03 pm    Post subject:
Hey Fuzzybee,
I am also in need of a few of the green connectors, (Phoenix connectors) for my PS-PRO IIs.
I saw you were able to help the OP, and was wondering if you had a way or any information on getting these.
Thanks for all you help,
-Dustin
Posted: Mon Mar 28, 2011 12:35 am    Post subject:
They are all over the place. It's the new de facto standard for pro audio equipment. Try the links that I posted above.
dadude712
Posted: Mon Mar 28, 2011 1:36 am    Post subject:
Thanks for the reply, I found one on the site above, but am not sure if it is the exact fit that I need.
http://www.newark.com/phoenix-contact/1757035/terminal-block-pluggable-4pos-24/dp/71C4154?in_merch=Popular Products&in_merch=Popular Products&MER=PPSO_N_C_EverywhereElse_None
