stgdz
| Posted: Sat Jan 24, 2009 9:15 pm Post subject: How do I display 1080i in vista with ATI? |
actually its a windows 7 installation but nonetheless how do I change the resolution to 1080i?
I am still setting it up on my desktop but I didn't see a 1080i option in the display pannel. Its a 4x3 monitor but the display pannel has a option for 1280x720 and 1920x1080, but I believe both of those options are progessive.
benareeno
| Posted: Sun Jan 25, 2009 2:37 am Post subject: |
You'll have to install powerstrip....I think. Unless 1920x1080 has a 30Hz option.
Powerstrip is great anyhow...you can tweak an exact doubling or tripling of the movie framerate...
stgdz
| Posted: Mon Jan 26, 2009 5:14 am Post subject: |
| benareeno wrote: | You'll have to install powerstrip....I think. Unless 1920x1080 has a 30Hz option.
Powerstrip is great anyhow...you can tweak an exact doubling or tripling of the movie framerate... | I always thought Powerstrip didn't work in vista.
MikeEby
| Posted: Mon Jan 26, 2009 6:28 am Post subject: |
Nope...works fine in Vista, there is some qurkeyness to make 1080i work with Vista. You have to go into ccc and force into 1080i then start PowerStrip and create your custom 1080i timing.
benareeno
| Posted: Mon Jan 26, 2009 5:27 pm Post subject: |
I didn't have to do that...it just worked...both powerstrip and 1080i.
nuttall_chris
Joined: 08 Mar 2006 Posts: 832 Location: Ottawa, Ontario, Canada
| Posted: Mon Jan 26, 2009 6:22 pm Post subject: |
Ben, what version of powerstrip are you using? I tried running powerstrip in vista but I had problems getting the proper refresh rates to work.
Chris.
benareeno
| Posted: Mon Jan 26, 2009 6:54 pm Post subject: |
I'll check when I fire it up next...I guess it was the latest version though.
| Posted: Tue Jan 27, 2009 1:50 am Post subject: |
| MikeEby wrote: | Nope...works fine in Vista, there is some qurkeyness to make 1080i work with Vista. You have to go into ccc and force into 1080i then start PowerStrip and create your custom 1080i timing.
Mike |
I had to do this.
Took me HOURS to figure it out.
Add 1080i as a "HDTV" resolution, then force it in CCC.
Then run PS and tweak it.
stgdz
| Posted: Tue Jan 27, 2009 10:51 pm Post subject: |
I have been playing with powerstrip over the last couple of days but for some reason CCC allowed me to use 720p. 1080i isn't listed so I am going to play with it more.
I have been reading this guide on and off http://www.ramelectronics.net/powerstrip.ep
Elaine Benes
| Posted: Thu Jan 29, 2009 4:27 am Post subject: |
Can someone please post their working 1080i 96 timings for Powerstrip in VISTA ?
MikeEby
| Posted: Thu Jan 29, 2009 4:35 am Post subject: |
| Elaine Benes wrote: | | Can someone please post their working 1080i 96 timings for Powerstrip in VISTA ? |
Kai posted these in his screen shot thread about a week ago. The dialog box looks to me to be Vista.
Elaine Benes
| Posted: Thu Jan 29, 2009 4:49 am Post subject: |
Superb, thanks for the post with the screen cap, that should help ALOT. I just tried my first res in Pstrip in VISTA and got locked into a scrolling display I couldn't get out of even AFTER I uninstalled Pstrip via Safe Mode...fun.
| Posted: Thu Jan 29, 2009 6:31 am Post subject: |
Paul, you have to override the EDID to allow big res's, and you also have to force 1080i 30hz in CCC first, to put it into "interlaced mode".
Then tweak in Powerstrip.
Elaine Benes
| Posted: Thu Jan 29, 2009 6:37 am Post subject: |
So how do you "force" 1080i 30Hz in CCC ? I have seen the option of adding HD resolutions in previous versions of CCC, but not this time, there is no mention of them in this version, with this card...
| Posted: Thu Jan 29, 2009 7:41 am Post subject: |
| Elaine Benes wrote: | | So how do you "force" 1080i 30Hz in CCC ? I have seen the option of adding HD resolutions in previous versions of CCC, but not this time, there is no mention of them in this version, with this card... |
Ooo...aahh..dunno. It's always been there for me - but i'm only on Cat 8.10 I think, on vista32.
What version are you running?
kschmit2
| Posted: Thu Jan 29, 2009 8:42 am Post subject: |
iirc I had to move the scaling slider to get rid of the scrolling in Catalyst 8.12 (Vista Ultimate 32Bit). It does not cause overscan or underscan.
I also had to choose 50p as refresh rate in the display properties. In previous drivers it had to either be 23.976i or 25i.
That's something which is strange, but has no effect on the image, since the actual values are injected by Powerstrip.
Kai
stgdz
| Posted: Fri Jan 30, 2009 11:36 pm Post subject: |
| Elaine Benes wrote: | | Superb, thanks for the post with the screen cap, that should help ALOT. I just tried my first res in Pstrip in VISTA and got locked into a scrolling display I couldn't get out of even AFTER I uninstalled Pstrip via Safe Mode...fun. | Well, I have been playing around with powerstrip a bit and got the 1080i working. Problem is, I don't have anymore resolutions now.
Just 1080i
And I need to get all my old resolution back so I can play my games.
edit-I got it working again.
How is powerstrip supposed to work with CCC though? If I add 1080i then do a restart I my resolutions should show up plus the 1080i correct?
