Barco 1209/2 picture goes away
OXCO
Posted: Thu Jan 22, 2009 3:00 pm    Post subject: Barco 1209/2 picture goes away
So, Sunday I am watching the first NFL playoff game and all of a sudden my picture goes away. After turning everything off and then back on it comes back........for 5 minutes and then goes away again. The projector is still running (fans running, some lights on) but no picture. I turn everything off and then back on again and the picture stays.........until the last 2 minutes of the second game. I tried all sources with the same problem.
Tuesday I tried again. This time the picture comes up, pulsates for about 5 seconds and goes away. The picture was fairly dim and not sharp. The time it takes the picture to disappear has accelerated from a few minutes to seconds from Sunday to today. Anybody have an idea? So far I have heard Quad or Power Supply. If it were the power supply wouldn't the whole projector shut down and not just the picture?
Go MAVS.
Posted: Thu Jan 22, 2009 3:32 pm    Post subject:
Check to see if the red EHT light comes on on the EHT board when the picture goes out. I'll bet it does, indicating a problem in the HV section.
Let me know. I'll shoot you an email as well.
OXCO
Posted: Thu Jan 22, 2009 4:01 pm    Post subject:
I will check it tonight. Which is the EHT board?
Go MAVS.
jkruger
Posted: Thu Jan 22, 2009 4:02 pm    Post subject:
Does the 1209/2 have the newer EHT in it?
OXCO
Posted: Thu Jan 22, 2009 4:14 pm    Post subject:
I believe it is the same as the 1209. I think the only dfference in the 1209 and 1209/2 are the neck cards.
Go MAVS.
Posted: Thu Jan 22, 2009 4:24 pm    Post subject:
I just replied to your email. I've got the parts in stock regardless of what version it is.
jkruger
Posted: Thu Jan 22, 2009 4:45 pm    Post subject:
I'm just curious whether the newer EHT fails as often as the earlier ones.
Posted: Thu Jan 22, 2009 5:02 pm    Post subject:
MOre often. Smile
It's actually not the EHT board that fails as often, the newer quadruplers are POS in my opinion. With a small mod on my end, you can swap the quad and EHT board to the older style. THey'll work the same.
