It's alive!!!
napos
Posted: Tue Jan 20, 2009 1:45 pm    Post subject: It's alive!!!
I finally installed my Marquee 9500LC Ultra! It has a few minor issues, but it's alive!
As you guys remember, I had a problem with my green tube, displaying some interference patterns. It turned out to be an issue with grounding on the green neck board. I secured the grounding leads and it was gone. The other issue it has is some "fungus" on the red tube, but it is only visible on certain occasions.
In general, I can clearly see the difference between AC and LC. The grayscale is so much better, the image has a 3D feeling that is scary at times and the colors appear to be brighter, more saturated, even without a red C element.
I have also noticed that light sources in night scenes have that bluish shade that you only get from a film projector.
I am guessing it is a combination from the HD10GT lenses and the Ultra platform, but the grayscale is so much better, even without defocusing the blue. With the blue defocused it is even better, and I need to defocus it much less than I did with my Marquee 8500 non Ultra with HD8 lenses.
Thank you all once again for all your help,
Nicholas.
Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
