deronmoped
| Posted: Sun Jan 18, 2009 5:53 am Post subject: Slow turn on. |
My 10PG all of a sudden takes a long time for the image to appear.
The tube heaters are lit, the HV sounds like it is coming on. I checked to see if it was source related, but the PJ's menus are slow to come on too. When I select a menu, I can barely see it in the face of the green tube and then it will slowly brighten. If I turn the PJ off after it has been showing a image and then turn the PJ back on the image comes up quickly. No error message. I reseated the boards in the card cage.
Any ideas?
Thanks, Deron.
| Posted: Sun Jan 18, 2009 6:07 am Post subject: |
I had something similar, but all tubes were dull. Turns out I had the 10PG's C board disconnected.. which sent the heater voltage down to 3.6 volts instead of 6.3. Put the C board back in, all was normal.
I asked Doug about it, he'd never heard of that, but I duplicated it on another 10Pg I had here.
| Posted: Sun Jan 18, 2009 2:56 pm Post subject: Re: Slow turn on. |
| deronmoped wrote: | | My 10PG all of a sudden takes a long time for the image to appear. |
Oh good, I was afraid you were complaining about a frigid girlfriend.
| Posted: Sun Jan 18, 2009 4:37 pm Post subject: |
Trust me, that's the first thing I thought of when I saw the thread title.
| Posted: Sun Jan 18, 2009 4:55 pm Post subject: |
How quicly things degenerate....
deronmoped
| Posted: Thu Jan 22, 2009 6:55 am Post subject: |
So, still the same problem.
I did some experimenting, changed out the system board and that did not change anything. I can turn the G2 up and see each tube light up, but no image. The image always comes up, but it takes like five minutes.
Could it be somewhere in the video train?
Deron.
larryk
Joined: 23 Aug 2007 Posts: 106 Location: Edmonton Alberta
| Posted: Fri Jan 23, 2009 12:05 am Post subject: |
I thought the same, I was going to suggest some lube and rub in circles:)
| Posted: Fri Jan 23, 2009 12:56 am Post subject: |
Put a meter on the filament pins. I'll bet it will creep up slowly.
Tinman
Joined: 09 Mar 2006 Posts: 1326 Location: Carson City Nevada
| Posted: Fri Jan 23, 2009 5:56 pm Post subject: |
I bet on the video output board. Rotten cap syndrome. Had 2 of them.
_________________ This space for rent.
