stgdz
| Posted: Wed Jan 07, 2009 9:37 pm Post subject: Subfloors for a basement? |
What are the advantages of a subfloor in a concrete basement and how thick are they usually?
zaphod
| Posted: Wed Jan 07, 2009 9:55 pm Post subject: |
warm.
dry.
let's you use hardwood flooring.
that said... lami works pretty darn good. and there are composite floorings that (for example) are essentially 4'x4' plywood squares with hardwood on top.
| Posted: Wed Jan 07, 2009 10:06 pm Post subject: |
| zaphod wrote: | warm.
dry.
that said... lami works pretty darn good. and there are composite floorings that (for example) are essentially 4'x4' plywood squares with hardwood on top. |
In addition, if you are going to use the room as living space, you can install radiant flooring. a great way tomake a basement livable.
_________________ Follow my blog
| Posted: Wed Jan 07, 2009 10:10 pm Post subject: |
Not only dryer and warmer as Zaphod indicated, but softer, too. A floor with any give at all is more comfortable to walk, sit and stand on than is concrete. Makes the basement feel less like a basement and more like the rest of the house if it has a little give - a little bounce.
If you have the headroom, you can use treated 2x4 on their wide side (sleepers) and sheath as you normally would. As Zaphod mentioned, you can also use a material like DriCore. It's fast and easy to install if you have some basic tools and a table or circular saw, but it's not cheap at $1.25-1.50/sqft...
http://www.dricore.com
If you want to spend a little less money and a little more time, you can also use a membrane material like DeltaFL and traditional sheathing:
http://www.deltafl.com
Midwest Basement Systems also installs a plastic tile designed to elevate the flooring off the concrete, but doesn't sell materials to DIY, and is very expensive to have installed. There are DIY alternatives, however if you've ever looked at "garage" tiles... It's in the same price ballpark as DriCore.
I'm leaning toward DeltaFL or the "garage floor tile" DIY method.
zaphod
| Posted: Wed Jan 07, 2009 10:29 pm Post subject: |
i cheaped out on a subfloor (and i didn't have the height anyway) by using 1/3 sleepers. worked a lot better than you might think. and because they're lying "flat" the reduced structural issues weren't. dropped some carpet on top and had a great little office.
my in-laws have water pipe radiant heat in the floors and it's really comfy. quiet too for a home theater. my two heating vents can distract me.
but don't discount the radiant heat sources that are not based on water pipes in the floor. there is that big roll stuff that goes under the floor and uses electricity. some of it even plugs into the wall!
| Posted: Thu Jan 08, 2009 10:46 am Post subject: |
dry.
that said... lami works pretty darn good. and there are composite floorings that (for example) are essentially 4'x4' plywood squares with hardwood on top. | Hardwood in the theater room? Excellent acoustical reflection properties YOU ARE NOT LOOKING FOR.
jask
| Posted: Fri Jan 09, 2009 6:02 pm Post subject: |
similar to SCs recommendations- you can carpet directly over this without the plywood deck.
********deleted****
Edit: sorry, this is the product to use if you want to carpet without a plywood deck over top: http://www.superseal.ca/all_in_one_subfloor.html
Herbie
| Posted: Mon Dec 14, 2009 7:38 am Post subject: |
Hello guys!
I use DriCore in my basement two years ago. and I would say yes it is worth using however the shims they provide are not the greatest. You will need more than they state. and most of the time in alot more than one corner two get the floor level.
Dricore benfits allow drainage and adequate support for additional flooring. It also helped bring the temperature up in my basement. MY basement used to stay a cool 45 degrees all year long now its an even 50 degrees doesn't sound like big jump but its noticeable to me...
| Posted: Mon Dec 14, 2009 11:26 am Post subject: |
Your basement stayed 10º colder than the average temp of the earth at basement grade? Sounds like an anomaly to me.
MikeEby
| Posted: Mon Dec 14, 2009 2:04 pm Post subject: |
Does having a wood floor sub floor have any acoustical benefits?
Lots of speakers come with spikes...I've always wondered what's that all about?
| Posted: Mon Dec 14, 2009 2:28 pm Post subject: |
I think a subfloor is generally a good thing acoustically, but I think a really good carpet and pad is comparable.
As for the spikes for speakers, I always assumed it was mostly so the speakers would stand up. A tall/skinny speaker standing on carpet/pad is not a good thing from a stability standpoint. The spikes go right through the carpet and pad so the speaker sits on the floor sheathing instead of the carpet.
Freak18
| Posted: Thu Jan 07, 2010 2:52 am Post subject: Re: Subfloors for a basement? |
The biggest advantage of sub floor for a basement was you can put virtually any type of flooring on top of it to fit your basement needs. And we know that the concrete makes the best basement sub flooring material is because you can seal it to make it water-resistance. Knowing the importance of basement are great to look for. Basement Dehumidifier
LOTREE
Joined: 19 Mar 2006 Posts: 401 Location: Paradise, Newfoundland
| Posted: Sun Jan 17, 2010 9:51 pm Post subject: |
If it's for insulating purposes I'd go with shiplap rigid foam insualtion [ pink(Owens Corning / blue (Dow) ] and Tuck Tape all seams then sheet with plywood.
If you want the 2x2' panels something like this:
http://www.ovrx.com/basement-insulation-science.html
and the reason I wouldn't go with the dimpled back OSB wood panels you see everywhere if temp/moisture is a concern:
http://www.ovrx.com/subfloor-comparison.html
I'm tempted to take up the subfloor in my basement apartment for the fact it gets so cold during the winter, -25C day with the windchill, and put down rigid foam.
_________________ Zenith Pro 1200x | Electrohome ECP 4500 | Yamaha HTR-5740 | HTPC & Speaker build to follow
| Posted: Sun Jan 17, 2010 10:30 pm Post subject: |
If moisture is a concern, you shouldn't be putting finished flooring down at all, and definitely not sealing it with a complete vapor barrier with no airflow ability.
Those Barricade panels look like a neat system, Greg - I hadn't seen those. The only thing I don't like is that if any water does reach the basement slab (due to intrusion, or from the room side), it will never, ever dry. It's stuck there. If you use the panels, it's also damn near $2/sqft... Getting to be nearly as much as decent floor finishes!
If you don't have a moisture problem, the foam idea isn't bad, though... I just looked up 1/4" Dow EPS, and you can get a 4' x 50' stack for $31, so ~$0.15/sqft. Throw a sheet of 15/32 Plytanium ($11.54/4x8) on top, and you're looking at about .36/sqft for a total of close to $0.50/sqft... Which smokes every other subloor method I've been thinking about. I just don't know if I like the non-drying aspect of it.
LOTREE
| Posted: Sun Jan 17, 2010 11:30 pm Post subject: |
Yeah, that was my concern with rigid foam on cement. While it is a 100% vapor barrier there is the concern of moisture underneath but it seems to be the new building code and I have yet to find anything stating otherwise especially on the topic of increased mold concerns. Considering rigid foam is also used for cement foundation forms and left in place I see no reason not to apply it after the fact. You'd certainly want to be sure there are no existing cracks and/or water seepage before tackling the job.
I guess with the elimination of the air space/movement under the floor you've also eliminated or greately reduced the introduction of mold spores. Watching Holmes on Homes is what made me want to tackle the project. I'm not sure of the exact YouTube video but I can find it if you like. I'll check when I get home.
LOTREE
| Posted: Mon Jan 18, 2010 12:42 am Post subject: |
Here you are: http://www.youtube.com/watch?v=4jSuWbdJy5A
