Satanier
| Posted: Wed Jan 07, 2009 7:44 am Post subject: 1080i on nvida card? (nvidia sucks) |
How can I do it? I've tried many times and it's just not working. I can't take it anymore. I'm running at 1080p 60hz right now and from what I understand that's not the best for an NEC XG-750. If I try to create a custom resolution it doesn't appear in the list, I cant set it when I enable the 2nd monitor, and if I set it to same on both displays I get a scrambled mess on the PJ in constant motion, looks seriously bad for the projector.
I also have a HUGE brightness issue still, but that will hopefully be fixed by the GammaX I ordered.
| Posted: Wed Jan 07, 2009 11:29 am Post subject: |
What video card and what OS? I have a 7950gt and custom resolutions worked fine in both the Nvidia control panel and powerstrip with XP,with Vista only powerstrip works and only some of the time.
yonexsp
| Posted: Wed Jan 07, 2009 5:36 pm Post subject: |
You can't do Interlaced on the 8xxx or 9xxx series cards. I switched to an ATI card. Plus the colours & 3D effect on the ATI cards is soooooooo much better than the Nvidia cards. Now I run 1080i@96hz, it is awesome!!!!
Satanier
| Posted: Wed Jan 07, 2009 6:10 pm Post subject: |
| yonexsp wrote: | | You can't do Interlaced on the 8xxx or 9xxx series cards. I switched to an ATI card. Plus the colours & 3D effect on the ATI cards is soooooooo much better than the Nvidia cards. Now I run 1080i@96hz, it is awesome!!!! |
I guess that's the problem, I'll start saving for either a dedicated home theatre pc with ATI, or my next graphics card will be an ATI. (I need something fairly fast for this pc, as I'm a gamer).
| Posted: Wed Jan 07, 2009 6:48 pm Post subject: |
I was doing 1080i on my 8600 card over a year ago. However only from the componenet output. everytime I tred the interlaced button in the Nvidia driver it would say "Resolution test failed"
So I went with an ATi 3850 single slot card 512megs ram. I hate to say it but it just works. ATi makes nice hard ware ( I've owned a dozen of their cards ) it was their software that left something to be desired.
Powerstrip works with this card too but sometimes it'll cause a blank screen requireing a reboot and a BIOS clearing. Ahh HTPC's whatdayagoingtodo?
yeme
Joined: 10 Aug 2007 Posts: 46 Location: Sandy Springs, GA
| Posted: Thu Jan 08, 2009 12:16 am Post subject: |
I am doing 1080i/60 with the 8600GT. I set my resolution to 720P, then go to manage custom resolutions (make sure to uncheck "Force HD resolutions" and check "Allow resolutions......." - Apply) put in 1920x1080/60/32 and check interlaced.
If the test resolution is successful, then save it-go to change resolutions and give it a go.
You are correct to not have dual display set when setting these custom resolutions.
yonexsp
| Posted: Thu Jan 08, 2009 4:42 am Post subject: |
| yeme wrote: | I am doing 1080i/60 with the 8600GT. I set my resolution to 720P, then go to manage custom resolutions (make sure to uncheck "Force HD resolutions" and check "Allow resolutions......." - Apply) put in 1920x1080/60/32 and check interlaced.
You are correct to not have dual display set when setting these custom resolutions. |
Your running XP right not vista
Satanier
| Posted: Thu Jan 08, 2009 7:07 am Post subject: |
If I try to make a custom interlaced resolution the projector becomes a "scrambled mess" it really looks terrible, it looks so bad I wonder if it could do damage.
yeme
| Posted: Thu Jan 08, 2009 8:51 pm Post subject: |
| Quote: | | Your running XP right not vista |
I am running Vista Home Premium. If I was getting that kind of corruption, I would reload the drivers after a clean uninstall.
An aside, this past week I started using 1080p at 48hz. JohnHWMan posted some timings he used and I was able to make a 48hz custom resolution that works for me. I only see flicker with white-background desktop items.
Satanier
| Posted: Fri Jan 09, 2009 2:24 am Post subject: |
| yeme wrote: | | Quote: | | Your running XP right not vista |
An aside, this past week I started using 1080p at 48hz. JohnHWMan posted some timings he used and I was able to make a 48hz custom resolution that works for me. I only see flicker with white-background desktop items. |
I've had this problem even after a windows reinstall. I don't think its going to work. I'm using 1280x720@72hz now and it looks quite nice, I just wish my green tube would focus properly. 1080p isn't readable enough for me on parts of the screen so I'll stick with 720 for now.
Gerbrand
| Posted: Fri Jan 09, 2009 4:59 pm Post subject: |
Hello,
I have 1080i@72 running with an NVidia 8600 over DVI.
Some things you have to get right:
1) Make sure that the number of active lines = 540.
2) Some older NVidia drivers seemed to have a sign error in the sync polarity when setting custom timings. The newer driver has solved this.
Gerbrand
yeme
| Posted: Fri Jan 09, 2009 10:50 pm Post subject: |
| Quote: | Hello,
Gerbrand
Would you post your custom timings for 1080i/72 for me?
Elaine Benes
| Posted: Sat Jan 10, 2009 2:02 am Post subject: |
| yeme wrote: | | Quote: | Hello,
Gerbrand
Thanks, |
I'd like to see those timings too if possible...
yonexsp
| Posted: Mon Jan 12, 2009 4:32 am Post subject: |
dittoe
