SYC
| Posted: Wed Dec 31, 2008 11:02 pm Post subject: Problem about centering the image of XG on 1080P/60Hz |
My XG is very normal to display 480i, 1080i, 720P. I was very happy with my XG untile yesterday when I tried to set it up with 1080p/60Hz from PS/3. It can lock the video signal, but the image is shifted to left very much. Even though I adjust the image shift control to the right limit, I can't make it centered. And when reaching the right limit of the shift control, the image like a little "fold back" on the right side. I am very sure the raster is in the center. Is there any way to solve this problem?
SYC
| Posted: Wed Dec 31, 2008 11:34 pm Post subject: |
You need a Scaler or a PC.
Or stick to 1080i.
This is a known issue. CRTs need custom timings for higher res's. Sony's seem to get away with it, but not NECs or Barcos.
MikeEby
| Posted: Thu Jan 01, 2009 12:09 am Post subject: |
Box 1020, problem solved
_________________ Chip
MikeEby
| Posted: Thu Jan 01, 2009 12:19 am Post subject: |
| stefuel wrote: | Box 1020, problem solved  |
Has that really been documented?...I would be surprised if it did fix the problem. The porch timings required are much different than standard 1080p timings.
| Posted: Thu Jan 01, 2009 12:27 am Post subject: |
Worked for me. AmPro's suffer greatly in that catagory. The Box 1020 solved it perfectly.
| Posted: Thu Jan 01, 2009 12:46 am Post subject: |
| stefuel wrote: | | Worked for me. AmPro's suffer greatly in that catagory. The Box 1020 solved it perfectly. |
Hey Chip do you get any 'flagging' at the top of the image in high def modes? I get it anywhere past 1024x768/60
| Posted: Thu Jan 01, 2009 2:13 pm Post subject: |
| AnalogRocks wrote: | | stefuel wrote: | | Worked for me. AmPro's suffer greatly in that catagory. The Box 1020 solved it perfectly. |
Hey Chip do you get any 'flagging' at the top of the image in high def modes? I get it anywhere past 1024x768/60 |
By "flagging" you mean???
There is no difference in the image, It just allows me to set phase to 50% rather than 98-100% to center the image at 1080P
| Posted: Fri Jan 02, 2009 7:34 am Post subject: |
Sorry assuming poeple can read my mind this week....
Image at the top of the screen bending to one side at resolutions over 1024x768
