Marquee Brightness pulsing up and down
HK-Steve
Posted: Wed Dec 31, 2008 2:01 pm    Post subject: Marquee Brightness pulsing up and down
Hello all,
Happy New Year to everyone,
we have about another 9hrs till I let off the fireworks off our terrace Laughing
Just a quick question about my friends Marquee 9500LC,
His image seems to do this intermittently, brightness decreases/ or increases about 3 clicks,
then back to normal then cycles randomly up and down.
It is random, can do it from first turn on, or like 2hrs later, then starts.
I went through his complete machine and cleaned every contact and socket.
His room is very cold around 10'c at the moment, but I don't see this as a problem, as there is no humidity.
I will be checking his supply voltage from the wall outlet, but I don't think that this is the cause.
Would appreciate any idea's or comments.
Cheers
Steve
Posted: Wed Dec 31, 2008 3:03 pm    Post subject:
Is it defocusing as well or just gets dim then comes back up, and is it for all tubes? if all tubes then its not the VNB's.
Vim, CLM or a Power supply i'd bet.
Hopefully Curt or Tim will know more, i have not seen this yet, just the defocusing and cutting out issue.
Posted: Wed Dec 31, 2008 3:33 pm    Post subject:
Too bad my sister isn't a tech (unless you need some cancer research done), she's in Basel right now..Smile
If this is floor mounted, then I'd suspect a glycol leak that's gotten into the backplane.
If not, then the last 9000LC I had this happen in (red tube only) was the CLM or VIM. I sent the customer both, he replaced both, problem went away. It could be the HVPS but I doubt it.
HK-Steve
Posted: Thu Jan 01, 2009 9:14 am    Post subject:
Yes it is all 3 tubes,
Ceiling mounted.
Hmm, Thanks for the pointers, I will swap out both and see if it fixes.
I don't wish cancer upon anyone,
Hope your Sister is enjoying the fresh dump of snow we had last night.
Cheers
Steve
Posted: Thu Jan 01, 2009 9:24 am    Post subject:
Happy new year Steve ! Good luck Thumbs Up
Posted: Thu Jan 01, 2009 2:37 pm    Post subject:
Should'a bought a ........ oh you know Mr. Green
Posted: Fri Jan 02, 2009 7:36 am    Post subject:
Never gives up Laughing
