Can someone check this!! Catalyst 8.12 Vista fix
yonexsp
Posted: Tue Dec 30, 2008 5:10 pm    Post subject: Can someone check this!! Catalyst 8.12 Vista fix
Resolved Issues for the Windows Vista Operating
System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows Vista. These include:
• Setting shadow quality to high or medium may cause flickering in World of
Warcraft
• Age of Conan DirectX 10, may intermittently become unresponsive during
game play
• Catalyst Install Manager, the 'Deselect All' button will improperly mark
installed packages
• The display driver may fail after being installed on an ATI Radeon HD 4800
Series or ATI Radeon HD 4870 adapter
• Returning from system standby may cause some video corruption to occur on
some OpenGL games
• Catalyst Control Center, AVIVO video settings are disabled under MS Vista
Does hti sfix the gamma control in Vista for ATI cards?
yonexsp
Posted: Fri Jan 02, 2009 8:53 pm    Post subject:
Bump
benareeno
Posted: Fri Jan 02, 2009 11:57 pm    Post subject:
Hopefully I can tell you soon...just got a new motherboard with ati onboard. I'll install vista tonight and try this driver.
You still running the fan modded XGLC?
yonexsp
Posted: Sat Jan 03, 2009 2:12 am    Post subject:
Hi Ben,
Still running the XGLC but it was my old AC one that was fan modded. But I will be modding this one soon enough
yonexsp
Posted: Sat Jan 03, 2009 3:54 pm    Post subject:
I installed an ATI card last night and it does not work. Though the colors are much better, and the card does not crush blacks as much as the Nvidia card. Also, now I have it running at 1080i@96hz sweeettt!!
Silky smooth now
There is supposedly something called dynamic contrast in the latter cards 4850 and up, has anyone seen this? It supposedly is like an adaptive gamma control or something.
Does anyone else note how much better the colors are with ATI vs Nvidia?
benareeno
Posted: Sat Jan 03, 2009 5:46 pm    Post subject:
did you check my other post about getting gamma with ati? Seems to work for some...and it will probably work best from the vga out. ATI is probably the best solution for crt'ers now.
yonexsp
Posted: Sat Jan 03, 2009 6:32 pm    Post subject:
That 3rd party cgc software thingy did nothing but adjust desktop gamma
benareeno
Posted: Sat Jan 03, 2009 7:31 pm    Post subject:
that should not be the case...you have to load the lut on boot. The lut changes gamma inside the video card...should apply to all sources.
benareeno
Posted: Sat Jan 03, 2009 7:32 pm    Post subject:
read this thread...
http://www.avsforum.com/avs-vb/showthread.php?t=1097653
David_Web
Posted: Sat Jan 03, 2009 8:09 pm    Post subject:
"The lut changes gamma inside the video card...should apply to all sources."
Not really. It changes the windows LUT that in turn asks the graphics card to use that LUT when rendering the image.
It does not however apply to all "sources".
The cursor, or "overlay" draw mode is not affected.
Powerstrip does support writing directly to pallet DAC on the graphics card but it still won't apply it directly to the outgoing signal which would be the desired behavior.
I would be glad if there was a way to apply it directly to the graphics card but I guess Ill have to wait for that. Unless I manage to work it out myself.
benareeno
Posted: Sun Jan 04, 2009 3:59 am    Post subject:
This software is posted in the htpc section...by a display calibrator. What the hell will it work with then? He claims it will work with powerDVD etc...if it didn't, then what would be the point of it? I'm betting it WILL work...
yonexsp
Posted: Sun Jan 04, 2009 5:34 am    Post subject:
I posted int here. It was in the Calibration section not the HTPC section. I think that was the confusion. It works with the desktop for calibrating displays, but after trying it it doe snot work with BD on ATI cards.
On top of that, I have a good friend at ATI who works in the group which writes the display drivers for video, and he already told me it won't work. He suggests I try a 48xx series card and the new Dynamic Contrast feature
benareeno
Posted: Sun Jan 04, 2009 10:48 pm    Post subject:
Why do I stlil think you're wrong here? I gotta get this damn pc built!
MikeEby
Posted: Mon Jan 05, 2009 12:16 am    Post subject:
I got tired of waiting and got a GammaX, it just works. No drivers just slide the pot to increase your gamma.
benareeno
Posted: Mon Jan 05, 2009 1:46 am    Post subject:
Sure..if you want to drop $100 and have another device in your signal path. I'd be far happier having the adjustment on the pc...hopefully this just works too Smile
MikeEby
Posted: Mon Jan 05, 2009 2:04 am    Post subject:
I agree with you, but the time fiddling around and not getting anywhere was aggravating.
As far as signal degradation there wasn't any see the 1:1 test patterns below. These were actually with the Box 1021, but the results were the same with the GammaX. Also note this is 1080p@72Hz with a pixel clock over 200Mhz. Notice the patterns with the box are the same intensity which is optimum without the box they were not.
With Box 1021
Without Box 1021
I hope you get the results you’re after, I'm just not optimist.
benareeno
Posted: Mon Jan 05, 2009 2:58 am    Post subject:
I'm optimistic about it...this software allows allows greyscale tuning by ire level...so any blue hump in the greyscale can be removed via software. This could take the pc to the level of the good scalers both with gamma and greyscale options.
And I'm sure there is no signal degradation...it's just annoying to have a device in the chain vs a direct hookup.
Ben
Posted: Mon Jan 05, 2009 3:46 am    Post subject:
Ben
It's even more annoying when you forget you un-pluged the power adaptor and wonder why you can't get a picture! Laughing
MikeEby
Posted: Mon Jan 05, 2009 4:11 am    Post subject:
Ben
The GammaX power connects right to a USB Port, no power supply needed.
Posted: Mon Jan 05, 2009 5:45 am    Post subject:
Ben
Yeah I know. But I'm using the Box1020. I just got my GammaX. That LED is STOOPID bright. IT's right up there with the one in my HDDVD/Bluray combo drive!
