Which approach would you take?
Fenster
Posted: Mon Dec 29, 2008 9:53 pm    Post subject: Which approach would you take?
Looking for some advice.
In my current set-up I use an Extron SW6 AR HVxi RGBHV switcher to route several sources through a 25 foot cable to my NEC XG-1101. I’d like to add HDMI support.
Should I get an EXT-FULLHD for the HDMI conversation at my equipment rack and then route it through the Extron and 25 foot RGBHV cable, or should I run a separate 25 foot HDMI cable to an XG-FULLHD installed in the projector. Which do you think would provide the better picture?
Thanks.
zaphod
Posted: Mon Dec 29, 2008 10:15 pm    Post subject:
our setups are fairly similar.
i convert Blu-Ray HDMI to RGBHV with an HD-Fury plugged into my Extron DVS-304. that passes through 25' of Extron RGBHV cable to my NEC XG-1101LC, with a brief pit stop at a Kimmy 2200 to tweak gamma.
i did run without Kim's 2200 and was more than happy with the result - although the 2200 did make it better.
i do all the switching/scaling/converting at the rack and feed the one RGBHV to the projector. i'm moving in a few months and will set up the new room in the same way, i think that it is the most flexible approach. i could run HDMI to the projector, but i have a number of non-HDMI sources and that would me converting them or running two cables and maintaining two convergences.
Fenster
Posted: Tue Dec 30, 2008 8:20 pm    Post subject:
Thanks for the reply zaphod. It sounds like you've got good results running via the RGBHV cable.
Does anyone here with experience running 20 - 30 foot runs of HDMI vs RGBHV have any comments on any picture quality differences that might be expected?
