Sony Full HD Card issue with PS3 setting at 24hz
haireez
Posted: Sat Dec 27, 2008 6:01 am    Post subject: Sony Full HD Card issue with PS3 setting at 24hz
Dear All,
I'm not sure if anyone else have the same issues as me. Before installing the Sony full HD card last week, I was using my HD Fury without any problem.
It seems that when I play a blueray disc, the picture start rolling and very unstable such as shifting the picture to the left side. I did tried so many setting on the G70 such as clamp setting to H/C etc but it still roll.
The only solution that can prevent the pictures from rolling is to change the setting on my PS3 of the BD 24hz setting from 'auto' to 'Off' and problem will be resolved immediately.
I just send an email to Moome regarding this issues and at the same time, I'm hoping that someone has an answer whether this new Sony Full HD card should be able to resolve at any resolution / hz etc or is the card is faulty.
Any advise is greatly appreciated as I don't encounter this issues with my HD Fury.
Best Regards
Faizel
Posted: Sat Dec 27, 2008 6:35 am    Post subject:
You found your own solution. No CRT projector will synch to a 24hz refresh. Leave the 24hz setting set to "off", so the PS3 will display at 1080p @ 50 or 60hz. If you want to display at 24hz (or a multiple thereof) to eliminate 3:2 pulldown judder, you'll need an outboard processor that can take the 24hz source and frame double or triple to display it at 48 or 72hz.
Cheers,
haireez
Posted: Mon Dec 29, 2008 2:22 am    Post subject:
Thanks for your explanation as this mean that the card is not faulty at all.
Regards
Faizel
2 White Vision 1
moome
Posted: Tue Dec 30, 2008 4:34 am    Post subject:
G70 vertical refresh rate is 38~150Hz, so 24Hz is too low for it~
haireez
Posted: Sat Jan 03, 2009 4:21 pm    Post subject:
Just for everyone info, below is how you set the 24hz video setting to 'Off'
1) Go to Video Setting Mode,
2) Scroll down to 'BD 1080P 24 Hz Output (HDMI) - Off'
Must set this to Off then everything will be fine.
Best Regards
Faizel
bigleechild
Posted: Sun Jan 11, 2009 1:17 am    Post subject:
What is up with my g70 in that when I put a 720p game in my ps3 the picture is completely out of convergence. I have a moome sony card and a denon 3808ci receiver. I haven't tried playing a 1080i or 1080p game yet. I originally had problems with bd before talking with Faizel. The movies play beautifully, now just trying to figure out games. Anyone else have this issue? Do I have to converge for 720p as well as 1080i and 1080p? This site rocks. Thanks for the help.
BLC
Posted: Sun Jan 11, 2009 2:58 am    Post subject:
BLC
b
Yep 720P is a new memory block. You need to atleast copy over a memory block and do the final tweaks. Or just do it from scratch.
