Heywood Jablome
| Posted: Mon Dec 22, 2008 6:56 pm Post subject: Todays candidate for most over-mis-used use of 'lamps' |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170289126419&ssPageName=ADME:B:SS:US:1123
| Quote: |
YOU ARE BIDDING ON THE BLUE PROJECTION TUBE FOR A REAR PROJECTION CRT HDTV
IT HAS BEEN TESTED TO WORK PERFECTLY
CAME FROM A PANASONIC 56" CINEMAVISION TELEVISION
WILL FIT OTHER TVS AS WELL
THE BRAND/MODEL NUMBER OF THIS ITEM IS:
DELTA DIGITAL 260
B TXFCRT27GSER
SHIPPING IS $15.00 THANKS FOR LOOKING
Note: Please don't purchase this item unless you know this is the correct lamp for your application. If you're not sure if this lamp will fit you set please feel free to ask. I don't give refunds for lamps that don't fit. My lamps have been test fired and allowed to run to make sure they're operational. There are other circuits inside a TV that will cause a lamp not to fire or run. I don't give refunds for lamps that won't work. I also don't give refunds for lamps that didn't fix a dim or dark picture symptom. A dim or dark picture symptom is usually associated with dirty or clouded optics. Blown lamps are often caused by a defective ballast circuit or clogged air filters, don't install this lamp in your set until you know those items are correct as I don't give refunds for lamps that blow just minutes or hours after being installed into you set. There are reasons why lamps physically blow inside a set and it's not due to a bad lamp. Thanks.
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
| Posted: Tue Dec 23, 2008 5:15 am Post subject: |
Maybe he should rub the lamp. Then make his 3 wishes.
