benareeno
| Posted: Sun Dec 21, 2008 8:25 am Post subject: Barco issue...flashes and noise in very low level scenes |
Sort of like brightness flashes on the lowest level scenes which are virtually black. Almost looks like a loose connection, but only when the pic is black or very close to black.
I suppose this is G2 or a neck board...is this common with the 808s?
I guess I should isolate which tube is doing this(I think it's blue) and then try to adjust G2 accordingly?
If that doesn't solve the problem, then is it most likely a neckboard?
Ben
