GammaX converter in HDFury2... worth it?
emz
Posted: Mon Dec 15, 2008 10:48 pm    Post subject: GammaX converter in HDFury2... worth it?
We am thinking of purchasing an HDFury2 to supply HDMI signals to an AMPRO 4600. Is it worth to get the $339 "advanced" kit with the GammaX converter gizmo? We are confused about this, since there seem to be no controls, just a fixed gamma shaping... it wouldn't do to spend an additional $99 to get a worse picture. Any help would be appreciated!
Posted: Mon Dec 15, 2008 11:19 pm    Post subject:
Gamma looks great on my Ampro 4000. There is an adjustment on the front of the GammaX it's a slider.
See here: https://www.curtpalme.com/forum_archived/viewtopic.php@t=13237.html
scroll down
Gary M.
Posted: Tue Dec 16, 2008 2:45 am    Post subject:
I suggest the XVue Box1020, words cannot describe how pleased I am with this based on early testing on my Sony Trinotron monitors
I am using a HDFury2 connected directly to the input and feeding the Fury 4:2:2 YPbPr from various sources
-Gary
Posted: Tue Dec 16, 2008 3:27 am    Post subject:
Xvue designed the GammaX. It's the Box1020 in a differnt form factor without the component output.
Posted: Tue Dec 16, 2008 4:49 am    Post subject:
There is an adjustable control the GammaX to control how much gamma boost to use.
All CRT projectors require some form of gamma boost to achieve correct gamma tracking. Without it they will be too dark across much of the scale. I've used and seen dozens (if not hundreds) of CRT projectors. Not one (when measured) will track gamma properly without some form of boost.
You can read about this and see example graphics showing before/after in my 'Greyscale & Colour Calibration for Dummies' guide:
Gary M.
Posted: Tue Dec 16, 2008 7:21 am    Post subject:
yeah I know, but I prefer the external little box, very nice quality, plus there is room for a tasty BNC mod Wink
either way if the GammaX is identical in performance to the Box units then I cannot recommend them enough Thumbs Up
-Gary
Axatax
Posted: Tue Dec 16, 2008 6:49 pm    Post subject:
Just curious, you have a VP50 - why don't you do the gamma adjustment there?
Gary M.
Posted: Tue Dec 16, 2008 7:20 pm    Post subject:
the DVDO units do not have a adequate gamma control, it is not point based and effects the whole curve itself, not isolated at the bottom IRE range
-Gary
