donr
| Posted: Mon Dec 15, 2008 10:21 pm Post subject: Ampro 4000 stuck in executive mode |
Hi guys
I was just wondering if the Ampro wired remote had some sort of executive setting? Mine seems to have stopped working for some reason. I can power on the pj, put it in standby and change channels. The numeric keypad is working but that it is. I can not access help or any of the convergence settings. Any ideas?
Don
| Posted: Mon Dec 15, 2008 10:25 pm Post subject: |
Yes it does Don, I'll get the code for you in a minute.
| Posted: Mon Dec 15, 2008 10:27 pm Post subject: |
Looks like CODE 37 for Executive mode.
| Posted: Mon Dec 15, 2008 10:29 pm Post subject: |
Try code 909. also check the memory battery. IF the set glitches, it might be weak, causing the glitch.
| Posted: Mon Dec 15, 2008 10:31 pm Post subject: |
What's 909 do? Hmmmmm
| Posted: Mon Dec 15, 2008 10:38 pm Post subject: |
909 takes it out of executive mode. Code 27 is some other limited function use. 909 is executive mode though.
| Posted: Mon Dec 15, 2008 10:39 pm Post subject: |
I'll have to try that.
EDIT: I changed the thread title to better reflect it's contents.
donr
| Posted: Tue Dec 16, 2008 12:17 am Post subject: |
Hey thanks. I will go and see if this helps and report back. And you are right, the tread title does better reflect it's contents.
Don
donr
| Posted: Tue Dec 16, 2008 12:26 am Post subject: |
Well, I don't know why it automatically went in exec. mode but code 909 did the trick. As always, your input is a great value. Will have to write down this one.
Don
