damien55
| Posted: Thu Dec 11, 2008 5:28 pm Post subject: BARCO Vision 708 MultiMedia |
I might be able to get a Barcovision 708 MM for a good price. I just wanted to know if this kind of unit is anygood to use with a HTPC at 1920*1080i?
It looks like the horizontal resolution is not great (Horizontal: 15-50 kHz / Vertical: 37-210 Hz / Bandwidth 45Mhz).
If the tubes are not too old (still need to get the runtime from the seller) is this unit going to produce a better picture than my Barco data 800 with a worn blue tube and two dark spots in the middle of the green tube?
Damien
jkruger
| Posted: Thu Dec 11, 2008 7:11 pm Post subject: |
The vision is a lesser projector than the data 800, not likely to a good move for you.
Edit: I stand corrected, I thought the Vision 708 was like the older analog machines.
jantje112
| Posted: Thu Dec 11, 2008 9:27 pm Post subject: |
A good 708 will outperform the 800.
Especially if the 708 is in good shape. Off course price has to be low
Elaine Benes
| Posted: Fri Dec 12, 2008 4:54 pm Post subject: |
| jantje112 wrote: | A good 708 will outperform the 800.
Especially if the 708 is in good shape. Off course price has to be low :) |
Totally agree with this, the 800 is ANCIENT, any newer 708 WITH GOOD TUBES will look quite a bit better...
