Signs a bulb is dying?
goofibulator
Posted: Tue Dec 09, 2008 3:05 pm    Post subject: Signs a bulb is dying?
All,
I've got a cheap Epson PowerLite S3. It's never been much of a track star, to be sure, but lately the image quality is really quite atrocious. The brightness is... well, not so bright, the blacks are green (quite green, actually), and the overall contrast and saturation is lacking.
So, I'm trying to determine whether these are the signs of the bulb reaching end-of-life. If so, I might consider trying to track down another bulb, or it might be time to move on. Like I say, it's a cheap projector, but the kids like to use it to watch movies.
Any suggestions on how to extend the life of the current bulb by playing with the settings (which I have done) would also be appreciated.
alan
Person99
Posted: Tue Dec 09, 2008 3:13 pm    Post subject: Re: Signs a bulb is dying?
goofibulator wrote:
All,
alan
How many hours are on the bulb?
The only real measurements I've seen suggest that on average the bulb is about 70-80% as bright as new at about 700-800 hours. When you start getting close to 2000 hours, they are about 50% as bright as new.
1 time of turning is equal to several hours of usage, so it you turn it on alot just to use for 30 minutes or so, it will wear faster. If it stays on for long periods of time (5-6 hours each time) then it will last longer.
In the end, even if it will take a bare bulb, the bulb is about $200. If it needs a full lamp assembly, you are talking over $250. This will be to keep a crappy 800x600 LCD business projector going.
For under $800, you can get a used 720p digital that will have an overall image better than most CRTs. For $500, you can replace the 800x600 PJ with a better 720p LCD (these will not have an overal image better than the CRT).
For instance, I saw a panny 900 on AVS the other day for $500. Why even both replacing the bulb? Sell it on ebay for $100-150 and replace it with a $500-800 PJ. Doesn't cost much more than buying a new bulb for it and you get a better picture. Heck, pop a few hundred more and depending upon what CRT you have, you might get an overall better picture than it!
Posted: Tue Dec 09, 2008 3:51 pm    Post subject:
The blacks being green also concerns me. I wouldn't think a bulb with low light output would shift the color of just the blacks (or low IRE material). I know the bulbs color temp can shift as it wears, but that would shift everything all one direction, i.e. the entire picture black to white could take on a slightly reddish or greenish hue, etc. I'd actually be a little suspicious that there could be a problem with the LCD panel(s). Aren't some LCD's famous for the color getting whacky as they get older?
I'd probably take a look and see what they're going for used on fleabay. It probably won't be worth it to replace the bulb. For instance, if you could get $300 for it with a brand new bulb, but $150 for it as-is, then unless you could get a bulb for $150 (not gonna happen), it won't be worth it.
Person99
Posted: Tue Dec 09, 2008 3:55 pm    Post subject:
Early LCDs like this were made with organic LCD panels. These die and start having problems (not completely changing state, etc). so it is likely his panel in the green light path will not completely go to the "black" state causing this. Just one more reason to get rid of it.
Newer LCD panels are made with an inorganic material. They still suck but they are better than the organic panels.
goofibulator
Posted: Tue Dec 09, 2008 4:03 pm    Post subject: Re: Signs a bulb is dying?
Thanks for all your wise councils. Your thoughts echo my own.
The bulb has maybe a thousand hours on it, but I got it used via craigslist and strongly suspect that it was tampered with. The dude had a bit of a dodgy story to tell about how he came into possession of the unit.
Yes, I've thought that perhaps it was the LCD panel(s) that were going... it really is green in the blacks, but colour rendition is (if you can see beyond the green blacks) still fairly OK.
I am leaning towards picking up a new unit, and I think that now might be the path I take.
alan
Posted: Tue Dec 09, 2008 4:41 pm    Post subject:
Sounds like you're on the right track.
Not to highjack the thread, but this is technically related, I suppose...
Dave, speaking of dim digitals... We were at the folks' house for Thanksgiving and watched Polar Express with the kids in my dad's basement... He's got a Sanyo PLV-Z4. In my opinion, it was a pretty good projector for its time, also considering the price. I think he paid just under $2000 for it with a free bulb - when comparable DLP's were over $3000.
Anyway, one of the things I remember about it when he set it up was how bright it was. Now? I don't think it's as bright as my G70! I'm pretty sure it isn't even close. I couldn't measure it because I didn't have my meter along, but it looked pretty dim to me. He's running a 48x85.33 blackout cloth screen. Even if it's only ~1.0 gain, it should be significantly brighter than my G70 on Wilsonart. I'd be amazed if he even has 750 hours on it. It's never used for TV viewing, and when turned on, is used for at least a movie or two. I know it has an iris, too - maybe something's wrong there.
I'll get all the details in 3 weeks, but I'm curious what you think or what to look for.
Person99
Posted: Tue Dec 09, 2008 5:10 pm    Post subject:
First, when he got it, you had a 1271 right? Also, wasn't the 1271 on BOC or something like that?
Second, I think BOC is about .9 gain. Wilsonart is about 1.2-1.24.
In its "best" cinema modes it ranges from about 266-350 ANSI lumens. With 750 hours on the bulb, it will be in the 200-250 range--which puts it pretty close to your G70 for all white scenes and much lower than your G70 on 50% APL scenes (typical brightish scenes).
So, I calculate that he is probably seeing about 8 ftL on his screne right now.
I can't remeber your screen size (maybe 96")? So on an 100% 100 IRE screen, if your screen is 96" wide you are seeing about 6.5 ftL.
Now, he is not going to get better than 8 ftL. But, on a 50-70% APL scene, you are probably looking at at least 350 lumens. So you are probably seeing about 11.5 flL on those scenes. Quite a bit brighter than 8!
Lastly, this thing like all Sanyo LCDs does have an iris and it has a huge adjustment range, can actually drop the light output of the PJ all the way down to about 100 ANSI Lumens.
So, next time at his house, play with the iris, but keeping image quality paramount, you are not going to get it much over about 8.
This is one of those PJs that proves not all digitals are brighter than CRTs! Very Happy
Posted: Tue Dec 09, 2008 5:35 pm    Post subject:
Thanks, Dave. I'd guess your numbers are probably pretty close. I was getting 12 ftL on a 10% window on my laminate with the G70, but I never measured the full-field. 6 or 7 is probably about right. I doubt he was even getting 6-7 with the Sanyo. It looked REALLY lifeless. Dim. It will be interesting to measure it and put some numbers with my impressions.
I don't like his setup at all. I'm trying to convince him to completely redo his screen wall. I hate it. He's got cheesy power drapes, and his viewing distance is really long - >2x for the front row and probably close to 3x for the back row. I'd like to see him move the screen wall much closer to the seating - he's got plenty of room to do so. Let's say he could sell the Sanyo for some decent money and buy a better projector used to replace it... What would be your top 2 or 3 choices around $1000 - new or used?
Person99
Posted: Tue Dec 09, 2008 6:06 pm    Post subject:
Yeah, but he does not have "plenty of projector" to do so. Other than the panny, even with defocusing to reduce SDE, you'll have a hard time getting much closer than 1.8x screen width with a 720p LCD. Plus, unless he has real theater seats, then he is probably at least 5 feet between rows (eyeballs to eyeballs). So, if his first is really at 14' (2x), then is back is going to be at 19' or so which is a not COMPLETELY horrible 2.71. Measured in screen heights, he is definately out of the SMPTE recomended 3x height and his back row is further than 4x height (max recommended). You could try 12' and 17' to get 3x and just over 4x height for the rows, but I think the SDE will be too bad from 1.7x width on the front row. I wanted my front row at about 2.85x height (it is actually 2.84 when reclined) and I could not find a 720p LCD that I could do that with accept the Pannys, but I didn't like how they looked at all (of course, I don't like the look of LCD at all, but that is another matter).
I think when Gary tried the HS51, his primary complaint was that he had to sit further back than 2.1x width--which was also my primary complaint with this one back in the day.
