Hauppauge 1212 - record 1080i/5.1 from any component source
Clarence
Posted: Thu Dec 04, 2008 1:44 am    Post subject: Hauppauge 1212 - record 1080i/5.1 from any component source
This started as an OT tangent in this thread:
Microsoft's New Xbox Experience Launches
overclkr wrote:
Clarence wrote:
OK, I think I'm going to order one of the Hauppauge 1212 HD-PVRs to play with.
Sounds like it's easy to burn to DL DVD for playback on blu-ray players as long as you don't need to edit the clips (requires re-transcoding).
$211 at amazon, $219 at newegg
I tried adding the tag so Kal gets the kickback...
http://www.amazon.com/exec/obidos/ASIN/B0018LX0DY/?tag=curtpalmecrtp-20
Casey captured one of my Dtheater movies for about 15 minutes and burned to DVD in Blue Ray format and my PS3 played it back just fine as well as my PC.
It captures 2 seperate streams one audio and one video (.TS file), it took about a whole 20 seconds (about 20 minutes of video) to transcode the two into a single .ts file that he used to burn to BD format all using his laptop. It worked great and was VERY easy to do.
You can also schedule the PVR to record which is pretty sweet as well, not to mention ANY HD component capable device can be hooked up to it.
If you wan't, I can try to upload the clip he did at my place so you can check it out..........
Cliff
The Hauppage arrived and I've been playing with it this week...
Overall: Thumbs Up
It does record HD from any component source very nicely and the results look 99.44% as good as the original. The editing software needs some work.
The native TS files don't playback on my X360 or PS3, but it does have conversion software. Takes quite a while to convert using the little celeron xp media center that I use for streaming. But burning to BD format on DVDR or DL is fast and easy.
Downside: the homebrew DVD/BD is 1080i... it doesn't upscale to 1080P when played back on the PS3. Which is a pisser because even 480P DVD scales up to 1080P. But PQ and 5.1 AQ is pretty nice.
It comes with some decent authoring/conversion utilities. I tried making a HD demo disc... 6 HD concert clips with a menu ran overnight... took ~20 hours to convert, author, and burn. But that was with TS clips previously recorded, not in the device's H.264 format. When burning a 60 minute concert that it captured, it only took a few minutes to burn.
Since my DVR isn't letting me capture .ts files anymore, it looks like I'll be archiving to DVD in BD format.
Tonight I'll try recording HDDVD and DVHS.
I only have HDMI from my PS3, so I might buy a PS3 component dongle to try recording BD.
greg_mitch
Posted: Thu Dec 04, 2008 3:46 am    Post subject:
What sort of storage space are we talking here?
Does it always go to 1080i or will it do 720p?
What sort of settings are there?
Can this be integrated into a media center for capturing HD from an HD cable box and still be scheduled to record from media center?
SOrry for all the questions but I figured since you started a new thread you were looking for discussion. I have no idea what this box is capable of...off to read some more.
Clarence
Posted: Sat Dec 06, 2008 3:00 pm    Post subject:
At the default settings (9 Mbps) , a 2 hour movie takes about 8.5Gb... perfect size to burn to DVDR DL. Cool
An hour long show or concert takes about 4.5Gb... a perfect size for single-layer DVDR.
You can slide the bitrate higher (up to 13.5Mbps) for better PQ, or you can slide it lower to fit longer movies onto a single disc.
It will record in the native resolution (720p if the source's component output is set to 720p, 1080i if 1080i). But the disc authoring utility con convert to a different resolution. That's what took so long in the first demo clip disc that I made... I had a mix of 1080i and 720p... it took a long time to convert the previously recorded 720p non-AVCHD TS clips into 1080i AVCHD.
But if you just burn to disc in the captured resolution, it's fast. Plus you can insert chapter points and edit out any unwated segments (commercials, credits, etc).
FF (2x, 5x, 10x, etc) and chapter advance work well.
It came with TitanTV scheduling utility, but I haven't played with that yet. I just manually set the number of minutes that I want it to capture, press Play on the source, then press record on the 1212. So far I've captured HD cable, Blu-ray, HDDVD, and DVHS/DTheater. Thumbs Up
I think I might convert my HDDVDs and DVHS to "homebrew-Blu" discs (AVCHD burned to DVDR in Blu-Ray format)... this will free up some space in my rack.
Posted: Sat Dec 06, 2008 4:38 pm    Post subject:
Glad to see you like it big dog!!!!!!!! Very Happy
Cliffy
Clarence
Posted: Sat Dec 06, 2008 7:30 pm    Post subject:
Cliffy
Wait until you see my latest Blu-ray demo disc! Cool No longer am I constrained to over-compressed HD cable TS files... I've got great stuff from HDDVD, DVHS, and Blu-Ray. Thumbs Up
Unfortunately, the capture is only as good as the component output of your sources. Not totally lossless, but 13.5Mbps AVCHD is pretty sweet... tough to find any compression artifacts.
Posted: Sat Dec 06, 2008 8:10 pm    Post subject:
Can you put me on your list ? Wink
Did they get the 5.1 DD fixed ?
Clarence
Posted: Sun Dec 07, 2008 12:02 am    Post subject:
Yes Thumbs Up
You need to come to a HT meet. Wink
Posted: Sun Dec 07, 2008 1:47 am    Post subject:
Clarence wrote:
Yes Thumbs Up
Ummmmm, When??? Wink
