nec xg 1100 lenses
mountainman
Posted: Sat Nov 29, 2008 8:55 pm    Post subject: nec xg 1100 lenses
if the tubes are liquid coupled will lc be included in the product number on the sticker and how many lenses were offered for one built in october of 1996 ? the back of the case says miltisync xg110 but the label says xg 1100 s/n 3900267.
inside of the front cover is a sticker with tube numbers but no lense info. ---- thanks
Posted: Sat Nov 29, 2008 9:19 pm    Post subject:
Do you have a picture, likely HD-144/145 lenses if AC, I believe HD-18 if LC, the lenses should have a ID sticker.
Posted: Sat Nov 29, 2008 9:23 pm    Post subject:
An 1100 is not an LC unit. An XG 110LC is an 1101.
mountainman
Posted: Sat Nov 29, 2008 10:40 pm    Post subject:
ok --- no lc anywher on the unit so ac sounds like what i have --- is there a big difference in the 2 lense packages -- sorry --- no pic --- yet
mountainman
Posted: Sat Nov 29, 2008 10:43 pm    Post subject: lc
---- ok --- thanks -- wasn't sure and didnt want to go removing lenses and dumping liquid ---- now i can fire it up and see what happens --- hasnt been ran for 10 years
Posted: Sat Nov 29, 2008 10:52 pm    Post subject:
Both 144 and 145 are similar, they should both be color filtered and sharp lenses, the only difference will be throw distance. I believe the 144's have slightly shorter throw.
-Erik
mountainman
Posted: Sun Nov 30, 2008 1:03 am    Post subject:
ok ---- thanks eric ---- that pretty well answers all my questions so far ---- damn this thing is heavy ---- so far i hear mostly good things about this unit so i'll fire it up tomorrow --- gotta clean out the cob-webs and dust first --- thanks again -- mike
Posted: Sun Nov 30, 2008 1:11 am    Post subject:
Don't drop it Mr. Green
-good luck
kschmit2
Posted: Sun Nov 30, 2008 9:20 am    Post subject:
mountainman:
since your PJ is air coupled (AC) you should have a look at this tutorial:
http://www.curtpalme.com/Bleeding_CRT_Tubes1.shtm
fiddlesticks
Posted: Thu Dec 04, 2008 11:01 pm    Post subject:
HI all. Just picked up an NEC XG 1101, & a 1351 off of ebay. I'm picking up the 1101 from the shipper in the mourning. Got the 1351 because it had the acon, & higher bandwith. If these aren't junk, this will be my first CRT set-up. What mods can/need to be done to these? Will changing the lenses to 144/145s work, or even be an improvement? Also, fo Neutral r typical home theater, is there any advantage to the 1351 over the 1101? Thanks for any input.
Posted: Thu Dec 04, 2008 11:20 pm    Post subject:
1. The only mod I would do is to solder a 3 watt 100ohm resistor in the red fan wire to the fan on the deflection board, because is is a noisy little bugger, and the deflection board runs cool in an XG. When you know which board is the deflection board, you will be ready to do the mod Wink
2. LOL, you don't want HD-144 lenses, you have HD-18 liquid coupled lenses, WHICH ARE MUCH BETTER.
3. No advantage to the 1351 over the 1101, use whichever has better tubes.
