barco question
morlex13
Posted: Tue Nov 25, 2008 8:31 am    Post subject: barco question
hi everyone
someone can tell me if the barco 701 data and barco 701 vision are the same machines?
each projector can make 1280x720?
if nof,what is the best resolution for each?
thans you all
manu
Ile
Posted: Tue Nov 25, 2008 11:08 am    Post subject:
Depend about vision 701 model number, some are video only units (480i/576i) with plastic lenses. Some shows also progressive image (480p/576p). BW is only 20 MHz.
BV701MM (multimedia, R9000740) is like data, it scans up to 50 kHz and have 45MHz BW. Data and Vision MM both should show 720p, 768p and 1080i. Maybe bit soft though.
I would use those with 480p/576p for dvd and sdtv. 720p or 1080i for hd.
morlex13
Posted: Tue Nov 25, 2008 12:31 pm    Post subject:
ok thank you
i dont know if is it a MM version...
i am ask for it to the barco'owner...
i have another question Embarassed
on the projection screen ,i can see entirely the phospor area and not only the image area....
somebody have an idea about this?
i think what the g2 are too hight...
if somebody have an answer for this problem..
what can i do for correct it ?
thanks a lot
manu
Ile
Posted: Tue Nov 25, 2008 8:02 pm    Post subject:
It could be too high G2 or too high brightness adjustment. Usually barco brightness should be around 50, depend little about sources levels.
G2 set-up
http://www.curtpalme.com/ES_Tube_Projector_Gray_Scale_Adjustment1.shtm
