Gary M. Guest
| Posted: Fri Nov 21, 2008 5:13 am Post subject: XG 1352LC green is gone! |
so I am watching some TV and all of a sudden the green just left my image, totally gone
at first I thought maybe a scaler problem or source component or etc.(colorspace funkiness HDMI handshaking BS etc.), then I decided to pull up the menus on the 1352LC(mine are set to green only) well I found the issue, no green just a black box where the setup menus should be, so I power off and back on, still no green
no error codes
no weird glow on the raster
the green tube is fully lite with orange glow at back end
PJ runs fine just no green tube output
tried switching red and blue signal leads to green neck card and still no dice
any takers?
just in time for Christmas break with no school or etc, I just ordered 60 new BD's to enjoy until new year
thanks for the help guys
-Gary
| Posted: Fri Nov 21, 2008 5:35 am Post subject: |
Neckboard.
We've been missing you since the election
| Posted: Fri Nov 21, 2008 5:48 am Post subject: |
Send up the neck card, I can fix it.
Gary M. Guest
| Posted: Fri Nov 21, 2008 5:54 am Post subject: |
thanks guys, can I confirm by swapping out the neck boards?
yes Mark, I had to crawl out of my hole that I dug for myself after this country put me into a deep depression on the 4th
-Gary
Gary M. Guest
| Posted: Fri Nov 21, 2008 6:24 am Post subject: |
ok, managed to get the green neckboard out while ceiling mounted and without lowering the back card cage down, that was fun
Curt, I don't want to have to waste your time if not need be, is it possible for me to fix? I am pretty handy, what should I look at?
thanks for the quick reply guys
-Gary
MikeEby
| Posted: Fri Nov 21, 2008 1:28 pm Post subject: |
Hi Gary, good to see you back, well sort of, just kidding.... Isn't the green neck board the one with the fan on it, curious did you swap the fan out to a different one, I wonder if that could be the cause of the failure? That fan is one of the loudest in the projector IMO. I swapped mine out with a 100mm unit just held in with some velcro strips blowing on the heat sink. That was about 1500 hours ago, I hope I don't have problems too, I don't believe in fan mods for XG's but that sucker is just to fickin loud.
| Posted: Fri Nov 21, 2008 2:41 pm Post subject: |
Sorry, I don't give out component information. Send it up, I can fix it.
Gary M. Guest
| Posted: Fri Nov 21, 2008 5:15 pm Post subject: |
| MikeEby wrote: | Hi Gary, good to see you back, well sort of, just kidding.... Isn't the green neck board the one with the fan on it, curious did you swap the fan out to a different one, I wonder if that could be the cause of the failure? That fan is one of the loudest in the projector IMO. I swapped mine out with a 100mm unit just held in with some velcro strips blowing on the heat sink. That was about 1500 hours ago, I hope I don't have problems too, I don't believe in fan mods for XG's but that sucker is just to fickin loud.
Mike |
Mike, yes I did replace the fan, with a much bigger one on top of the case, that fan is a joke for sure, but it does make me wonder about this neck card, I did the mod 3 years ago so I guess that isn't to bad a span to not have a issue
-Gary
| Posted: Fri Nov 21, 2008 9:59 pm Post subject: |
I did some measurements, that fan only makes about 2 dec C difference to the neckboard heatsink. As long as you have some air moving over it, then that is not the issue. IMO no fan would be fine.
If you want to know for sure, swap the green for another colour.
Gary, Curt isn't going to tell you how to fix the neckboard - it's his livelyhood.
