Phase control not working on Marquee 8500
CRT_Ben
Posted: Wed Nov 19, 2008 6:11 pm    Post subject: Phase control not working on Marquee 8500
Playing with a Marquee 8500 that I have here, and the phase control won't work. The on-screen value goes up or down but the image doesn't move, it just jumps around a lot when adjusted, always ending up in approximately the same place. Same behavior for H. Phase and V. Phase. I have boards I can swap, but any ideas? The rest of the PJ seems to work great.
Also - I've seen two 8500's now with the older-style, non-pigtail HDM. I thought that style was the 8000/9000 boards, and that the x500 series all had pigtails?
TIA,
Ben
Posted: Wed Nov 19, 2008 6:37 pm    Post subject:
Hello
Try another control board or deflection processor (large board mounted on top of control board).
CRT_Ben
Posted: Wed Nov 19, 2008 6:45 pm    Post subject:
Tim in Phoenix wrote:
Hello
Thanks Tim, will do. I figured it might be, since H and V were affected equally and it's phase and not raster movement. I'll let you know what I find.
Posted: Wed Nov 19, 2008 7:16 pm    Post subject:
Check to see if the H width works over 50. Whenever I put an 8000 deflection board into an 8110/8500, that's what I saw. Width worked to 50, then stopped.
