I knew I would have to align a MARQUEE sooner or later :)
Graham Johnson
Posted: Fri Nov 14, 2008 12:50 pm    Post subject: I knew I would have to align a MARQUEE sooner or later :)
Ok I have been fiddling with the bugger for a few hours and it isnt that hard. But somebody please tell me how to move the godamn raster around the tube face.
I can move the image in the raster just fine, But how do I move the raster ??
Give me back a SONY to work on PLEASE!! Save me !! Twisted Evil
Graham
Posted: Fri Nov 14, 2008 1:16 pm    Post subject:
you need to use to focus coil and pysicaly move it. there are three wing nuts on it and you can move it around that way, aslo a little more with the CPC magnets used for astig.
Ile
Posted: Fri Nov 14, 2008 1:22 pm    Post subject:
You have to loose those three brass wing-nuts on the focus yoke and move focus yoke to center raster.
Have fun with tightening those wing-nuts without moving raster. Laughing
Edit. too slow...
Posted: Fri Nov 14, 2008 4:38 pm    Post subject:
First off you need to re-set the convergences so yuo know where the raster really is, go in to any convergence menu and push zero. Do this for the green tube as well in the service menu. Now push the # key and look to see where the rasters/grids are. If they're way off you can move the Focus coil around like has been mentioned, this requires cleaning off a lot of hot glue in most cases.
If you just need to scoot them a little bit it's fine to just go through the HELP - Guided Mechanical set-up menu. This input's an offset through the deflection curcuirty and can be used for fine tuning the raster center with no detrimental effects to convergence stability.
Posted: Fri Nov 14, 2008 6:00 pm    Post subject:
Everything they said...
This is one thing I really HATE about Marquee. The flipping wing nut thing is a real pain in the ass. Just when you have it perfect, you tighten down the wing nuts and the whole fing thing moves and you get to start over.
And then you get to do two pole focus again which also moves the entire thing so guess what, now it's time to loosen the wing nuts again for the next itteration.
Have fun your first time Mr. Green
